Finally I can capture HD with 5.1 audio with the Hauppauge 1512! The first capture was out of sync but tinkering with the software and my cheap Lanovo laptop I think I can archive these world series games after all!
Results 1 to 9 of 9
It's for real. The 2nd test I did I took the thumb drive to the side of my Samsung and my Onkyo A/V receiver switched to 5.1 automatically. I was so happy.
Still doing short 1 min capture tests. I don't think the encoder likes when you fast forward the DVR through commercials because the green light that goes around turns white on the box. -
I can't understand why people try to record TV broadcast...
I always recorded what I want with mic and video cameras.
I bought an 5.1 microphone set too only for audio recording. -
[QUOTE=jagabo;2637422] Here's what the media info says when I right clicked on the file. The Hauppauge software GUI shows what the incoming stream is on HDMI if it's 2.0 or 5.1.
It's the synch I'm hoping turns out ok. My avermedia card I've been using since 2016 was very good. -
Again, just because the source and cap are 5.1 doesn't mean there is sound on all six channels.
An update. The sync is fine even on long running files that are 4hours plus with 5.1.
It doesn't seem to like the mp4 format so I let it encode to .TS file
When navigating my computer takes a little bit of time to go to the spot where I mouse over the time line in .TS files. When I edit out the commercials and save to mp4 with videoredo the file is then able to go anywhere in the timeline with no hiccups.
100% satisfied with this product.
S-VHS PCI Capture card for cheap HuffYuv CAPTURE
By Tek03 in forum CapturingReplies: 26Last Post: 24th Jul 2021, 22:45 -
Capture via Magewell Capture Pro HDMI Not Interlaced
By GrouseHiker in forum CapturingReplies: 19Last Post: 29th Apr 2020, 08:08 -
Using Canon's EOS Utility to capture on screen video VS a capture card
By RoyZ7 in forum CapturingReplies: 0Last Post: 23rd Apr 2020, 07:18 -
Out of touch with video capture - USB capture device advice
By Lambchop in forum CapturingReplies: 7Last Post: 25th Nov 2018, 04:19 -
VHS PAL Capture - Very minor pink noise appearing on sports capture
By Robertp in forum RestorationReplies: 12Last Post: 9th Nov 2018, 19:50
