Trying to get some DV tapes onto my Win10 computer. The computer is detecting the camera after installing the legacy drivers for the IE1934 controller, shows as "Canon DV Camcorder" under imaging device and "Canon ZR85" under devices and printers. Camcorder is in playback mode with the AV->DV option turned on. I was able to get the device to work in Scenalyzer as "Microsoft DV Camera and VCR", but WinDV doesn't have it as an option under video sources.
	try moving the windv.exe to a folder that isn't in c  rogram program files folder, make a new folder called c:windv and put the exe in there.  once you've moved it, right click on the windv.exe, go to properties/compatibility and click the box to always run as administrator.  it's a win 8.1, 10, and 11 issue.
						-- rogram program files folder, make a new folder called c:windv and put the exe in there.  once you've moved it, right click on the windv.exe, go to properties/compatibility and click the box to always run as administrator.  it's a win 8.1, 10, and 11 issue.
  Canon ZR85 won’t eject tapesBy clokwise in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 30th Jun 2020, 06:56
  Is WinDV the best for old laptop?By WolfSpring in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 19th Apr 2020, 16:54
  Canon Legria HF G40 with Canon SM-V1 Surround Microphone ProblemBy dpaterson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 8th May 2018, 13:03
  Can WinDV capture DVCPRO50?By digicube in forum Capturing and VCRReplies: 5Last Post: 7th May 2018, 13:17
  WinDV-few questions anbout capturingBy SerbianBoss in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th May 2018, 15:42
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
