I've used the same potplayer for several years and had a lot of custom settings. For some inane reason i decided to update and didn't think of backing up my settings.
The new install reset all my settings, so i had to start over. After must work I've now gotten everything back to normal except 1 thing.
I used to have the PageDown key just to the next file in the same directory as the file playing. PageUp would go back 1 file.
This was not just moving to the next file in the playlist, but actually jumping to the next file, even when the playlist had only 1 file.
The 2 Seek buttons (<= | =>) in the interface would also move the next file if right pressed.
I simply cannot find the way i changed the standart PageUp/Down functionality and make it work like before, so any help would be appreciated.
Could this be something that used to be in a earlier version and was removed ?
Results 1 to 1 of 1
How do I import PotPlayer Settings?
By LeoL in forum Software PlayingReplies: 4Last Post: 8th Aug 2024, 05:38 -
Why on earth is PotPlayer playing mp4/mov/any video file like this?
By HorusOwl in forum Software PlayingReplies: 13Last Post: 20th Aug 2021, 00:11 -
potplayer: dvd video image and sound lost after update
By Vanlife in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2020, 21:12 -
What potplayer settings should I use?
By Chibi in forum Software PlayingReplies: 3Last Post: 18th Oct 2017, 10:29 -
PotPlayer (64-bit) updated and lost all my settings!!!
By Balema in forum Software PlayingReplies: 10Last Post: 8th Feb 2017, 06:39
