Hi all,
I have a DivX4 movie that I want to convert to VCD. I followed the "DivX to VCD All In One Guide" as found in the HOW TO / CONVERT section of this site, but after the conversion finishes, I get a new mpeg file with ONLY the audio. No Video...
Anyone has an idea?
I had the exact same problem when i tried to encode Ghost in a shell, and a nAVI movie, i hadn't had any problems previously with nAVI movies, i tried both TMPEGNC v 0.11.20.98 and the newest version. SOMeONE please help us!! :lol:
All work and no play, makes me wanna kick your f**king ass! -
Ok, I just downloaded the Panasonic MPEG Encoder Demo and wanted to follow the steps as explained in http://www.vcdhelp.com/panasonic.htm .
So I hit Select, choose my source DivX file, then click "use identical files" so it uses the audio from the avi source.
Then I select "VCD/NTSC Stream (.mpg)" in the Type section, and hit "Special Processing"... Nothing happens!!!
Tried then to use a separate wave file for the audio, same thing, when hitting "Special Processing", nothing happens.
So I try to encode it directly without using any special processing. I press "Start Encoding", and it gives me an error message not saying ANYTHING:
Here are the properties of my source DivX file as given by VirtualDub:
Hope this can help you helping us
Ok, after about 5 hours of late night / early morning reading, I found my solution...
In fact, the problem was in the AVI source file. I post how I could work out my problem so it could help other people.
- Open Virtual Dub
- File > Open Video File
- Video > Scan Video Stream for errors
- Let the process finish, you should then see in the status bar that a number of frames have problems.
- Video > Direct Stream Copy
- Audio > Direct Stream Copy
- File > Save as AVI
Then work with your new AVI to encode
Hope this will help someone...- A Life? Cool! Where can I download one of those from?
- I have a dream: 1,000,000,000,000 bytes free.
- The box said: 'install on Windows XP, 2003 or better'. So I installed it on Linux.
- Windows is NOT a virus. Viruses DO something
Need help converting to MP4 with TMPGEnc Express
By rede96 in forum Video ConversionReplies: 0Last Post: 11th Aug 2011, 16:29 -
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 17:12 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 29th Aug 2008, 00:33 -
Converting Video for a Blackberry using TMPGEnc
By Vachoen in forum Video ConversionReplies: 3Last Post: 9th May 2008, 16:06
