Thought I'd pass along something I had trouble finding an answer to online. I've authored lots of home made blu-rays from various digital cameras, downloaded videos, etc. I use DVDFAB of various editions over the years. All of a sudden my latest compilation would play the menu, and then the videos would not play on my old Panasonic DMP-BD75 (that one is my preferred one I use with my home tv), did not play on a SONY BDP-S195, but the videos did play on an LG BP135. The discs also played on my windows 10 PC with various software players.
I thought maybe a disc compatibility issue as I had recently not been able to find the Memorex 4X discs I had used for a long time, and tried several other brands and speeds. Even tried a new Blu-ray burner.
Long story short: the videos that would not play when part of an authored blu-ray compilation, had source videos that were 25 FPS (frames per second). Videoinspector, and Potplayer reported the FPS correctly, I note that Mediainfo did NOT report the FPS correctly on some videos.
The fix was to re-encode the 25FPS to most any other FPS. Seemed like 29.970 gave the least noticeable hiccups.
So if you make a BD-R and it plays the menu, and then won't play or only some videos play, then check the source videos Frames per second rate, as some stand alone players don't seem to play nice with 25 FPS.
	25 fps should be interlaced for BD standard, otherwise not all players will play. And if your player is for Japan/US/(some other markets) it may not play 25fps (at least Japanese PS3 does not).
  Whether videos encoded with H.265 can be played using HW acceleration?By bookagood in forum Newbie / General discussionsReplies: 4Last Post: 17th Aug 2021, 17:43
  Home Videos - Stream to media player w/DVD menuBy Jono15 in forum Software PlayingReplies: 4Last Post: 8th Feb 2021, 11:14
  [SOLVED] No-brainer Windows application to slice videos?By yetanotherlogin in forum EditingReplies: 12Last Post: 2nd Dec 2019, 23:25
  Why doesn't some videos fill the screen when played to a smart tv?By HeyRicardo in forum Video ConversionReplies: 13Last Post: 27th May 2018, 17:21
  advice for a media player that can be played X10 or moreBy Stokesy41 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jul 2017, 18:37
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
