Hi, there is an option in the Mpc-Hc menu "Pan&Scan -> Scale to panoramic screen", but there are some way to assign a key to perform this action instead doing though the menu?
There isn't in the version I'm using.
It's the latest, 1.7.13. Here is an screenshot of the menu. I'm in Spain, so these lines appears in spanish. It can be edited, but I never did, so seems the application created them in the system languaje although the application language was set to english.
So I would like to execute that action by pressing a key instead of having to go to the menus. If there is a way to assign a key to that menu line, as can be done with others.
Anyway, pressing numpad 9 several times achieves the same result. -
Assign "VidFrm Outside" to a key. AKA Video Frame -> Touch Window From Outside.
I did understand your question and AFAIK the answer is/was no. I haven't been following the latest updates very closely though.
Latest release is 1.9.17 (November 9, 2021)
https://www.videohelp.com/software/Media-Player-Classic-Home-Cinema
there is a startup switch to Specify Pan & Scan preset name to use if it helps:
/pns "name" -
Automatically pan and scan 2.35:1 and 16:9 videos to 4:3?
By rowjekto in forum Newbie / General discussionsReplies: 16Last Post: 3rd Oct 2021, 16:07 -
MPC-BE Zoom/Pan with subtitles
By ShaderKite in forum Software PlayingReplies: 3Last Post: 26th May 2021, 09:50 -
Feature request for mpc-hc & mpc-be
By babai89 in forum Software PlayingReplies: 5Last Post: 9th Aug 2017, 19:37 -
Pan & Scan in media player classic
By adamf154 in forum ComputerReplies: 0Last Post: 19th May 2017, 06:55 -
DAR: why scale down width rather than scale up height?
By chconnor in forum Video ConversionReplies: 15Last Post: 20th Feb 2017, 20:40
