Results 1 to 11 of 11
    May 2016
    Lithopolis, OH United States
    I am trying to convert some lossless .avi files to .mp4 or .mkv files but the thing is, I am not sure what is the default for converting to lossless .mp4 or .mkv. I want to do this in Virtualdub2 to make but is the default settings for any other type of converter such as Handbrake, RipBot, etc.?
    Aug 2013
    Central Germany
    To encode to lossless AVC video, you need to specify quantizer 0 (as documented in the help screen of x264):
          Lossless:
                x264 --qp 0 -o <output> <input>
    Please note that consumer players may not play lossless AVC. PC media players should be able, especially when using decoders based on ffmpeg / libavcodec. This means e.g. VLC, MPC-HC, MPC-BE, or installing LAV Filters for any DirectShow compatible player.
    May 2016
    What about in the Windows version of those very same codecs? Like x264 8 bit?
    Mar 2008
    Yes, that's the default, the command given produces such a file
    Aug 2013
    Central Germany
    The codec does not behave differently on different operating systems.
  6. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Have you considered simply using MKVToolNix? No re-encoding quality in = quality out, same with file size.
    Aug 2013
    Central Germany
    MKV will be able to contain the original video format from the AVI. MP4 requires one of a few supported video formats.
    May 2016
          Lossless:
    How do you translate this into the x264 configuration in Virtualdub2?
    Aug 2013
    Central Germany
    Just study the user interface.
  10. You can also use ffmpeg with -crf 0 for lossless avc/hevc encoding
    Aug 2013
    Central Germany
    CRF 0 may work too; but Constant Quantizer 0 is the primarily documented method.
