when i'm capturing with the dc10+ i don't seem to be getting any sound , i can hear it through my live drive but the capture file has no sound and no sound file has been captured , anyone help please .
hairybloke
epox 8k7a+,amd xp1600,256ddr,2*40gb h/d,plextor 40*12*40,prophet geforce 256(32mb),dc10+,creative platinum live drive, -
in control panel
open audio
make sure on recording it saysmiro dc10
and make sure use only prefered devices is checked
it is trying to use the live to record thats all -
still no good m8 check all control panels and audio is enabled but no sound on any captured video , any more ideas please
hairybloke
if it wasnt showing miro dc10 in audio properties then you will have to change it to that and recapture
That was Windows control panel you checked right?not control panel of capturing software -
as far as i can tell m8 it is saying miro dc10+ in the control panel unless i'm looking in the wrong place , in which case can you take me through it one step at a time and precise as to where to look . thanx for the help though m8 , i appreciate it very much .
hairybloke
in windows click on start in lower left then settings then control panel
double click on sounds and multimedia
click on the audio tab at the top
on playback set it to your sb live or whatever sound card you have
on prefered recording device make sure it says dc10
if not change it
at the bottom put a check in use only prefered devices
if it is already checked uncheck it and check it again
at the bottom click apply and ok
now try capturing some brief footage then play it back and see if it now has sound
if not check your cables,on my dc30+ the audio cables are always getting loose -
Originally Posted by hairybloke
You do realize that the DC10+ is a video capture card only, right? You have to feed sound into the "line in" port on your sound card (you may need a male RCA to male 3.5 inch audio adapter).
Assuming that you installed sound drivers and you connected the audio cable to the line in socket, your captured AVI file should have video and sound.
You are using Pinnacle Studio to capture, right? Or AVI_IO? Or VirtualDub?
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 14:54 -
Pinnacle AV/DV2 or DC10+B miserable performance
By cybertheque in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2008, 21:44 -
Miro DC10 + Fedora core 8
By bmw524 in forum LinuxReplies: 5Last Post: 7th Jul 2008, 07:28 -
Pinnacle DC10 Plus on Windows XP
By Paulsa in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 10:02 -
DC10 Plus Capture
By jackylhome in forum Capturing and VCRReplies: 1Last Post: 30th May 2007, 17:12
