Results 1 to 17 of 17
    Oct 2021
    Poland
    Hello, i have a TS MPEG4 file that has duration 10:33, but actually it has duration 10:22. Can someone tell me how to repair that TS file so it has duration 10:33?
  2. upload it somewhere and post the link here
    Aug 2013
    Central Germany
    The problem is probably: MPEG TransferStream files have no keyframe seek index. Analysis tools usually will not scan the whole file from the beginning to the end to count every GOP with a timecode, that would take quite a long time. Instead they rather rely on a header field which reports a planned average bitrate and divide the file size by it to estimate the playing time.
    Remultiplex this TS file to MP4 or MKV and you will get a reliable duration.
    Oct 2021
    Poland
    Oh, and i forgot to add that in some parts of that TS file there's a glitch thing that skips frames or seconds of the video.
    Aug 2013
    Central Germany
    Possibly damaged data, if the source is really DVB.
    Mar 2008
    Have you tried making an MKV from it MKVtoolnix GUI? This often helps
  7. Oh, and i forgot to add that in some parts of that TS file there's a glitch thing that skips frames or seconds of the video.
    It's only a glitch, a temporary setback.
    (Today I learned... that the actor whose character got blown to pieces in that infamous scene almost got his balls blown off by a misplaced blood squib...)
    Oct 2021
    Poland
    Okay, so i tried the TMPGEnc MPEG Smart Renderer and MKVToolnix and the original duration of the video was retained, but the video freezes on some minutes.
    Mar 2008
    This is because there is an underlying problem with the source
    In ffmpeg perhaps something like this:
    ffmpeg -fflags +genpts -i input.ts -vcodec copy -acodec copy "output.mkv"
    Oct 2021
    Poland
    I tried ffmpeg and tsdoctor, but still, didn't fix it for me.
    Mar 2008
    Can you upload this file? How are you so sure what the length should be
    Feb 2006
    try re running your file through ffmpeg using this - ffmpeg -i input -c:v copy -c:a copy output and see if it corrects
    the duration. - https://superuser.com/questions/863183/how-to-fix-ffmpeg-inaccurate-time-stamp-that-co...ail-generation
    Oct 2021
    Poland
    I tried that too, but the duration is 39:14 and there are still skips in seconds.
    Oct 2021
    Poland
    I tried MKVToolnix and the original duration is back, but there are still skips in seconds.
    Aug 2013
    Central Germany
    Well, as I already said ... if the source is Digital TV Broadcast, the reason might be signal drops. Then you lost some content.
