Hello,
You can say "I told you so" I deserve it, but I didn’t know Win 10 isn’t ideal for capture until it was way too late. I’m tired of not being able to cap with VirtualDub after every update. Even when I re-download older versions I still can’t capture. The only trick that works is restoring to a different date. But I’d imagine eventually that won’t work.
I’m thinking since I have a reasonably beefy Win 10 pc with all the desired hardware and software, should I just use it as a standalone capture device never connecting online, therefore no updates?
Is there a small unit, possibly a Raspberry Pie that I can use for internet-only yet share my current keyboard, mouse, monitors, has audio capability? I’m limited on desk space so I can’t have two towers.
Thanks for any suggestions, ideas etc.
Results 1 to 16 of 16
An old used laptop, I use a refurb with W7 “embedded “ in the hard drive.
Dirt cheap, leave offline, use the tower for editing, never look back. -
Thank you. Can I connect an external mouse & keyboard to a laptop? If I buy a W7 laptop I won't be able to go online. Did you mean buy a cheap Win 10 laptop and use that for internet and save the tower for capture?
I forgot to mention I had a dual-boot with my Win7 years ago, but kept having problems with my external soundcard (Focusrite Scarlett) so I had to do away with the dual boot. -
I leave my 15” Lenovo refurb offline.
It has W7 forever protected on the hard drive.
All I do is a factory reset, it installs 7, then I use a thumb drive to do my updates and install needed programs.
A mouse works fine, I don’t know about a keyboard.
The laptop is used solely for capture. -
Perhaps VirtualDub2 will work better with Windows 10 than the original. Have you tried it?
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
I have VirtualDub 2 64 & 32 bit and an old version of VirtualDub (1.9.11) and none worked after the latest update, until I did a restore.
Even though Win10 is crap for capturing I had good luck for a few years until these recent updates. I just want a small unit for internet, but would like to share my keyboard, monitors, etc with my current tower if I use that for standalone capture.Last edited by clashradio; 11th Nov 2021 at 17:23.
Beware that it's not easy to install Win 7 on modern hardware. You'll need a special install like this:
https://forum.videohelp.com/threads/384921-Windows-7-Image-Updater-SkyLake-KabyLake-Co...n-Threadripper
For USB capture devices you could use a BeeBox or an Intel NUC:
https://www.asrock.com/microsite/Beebox/
https://www.intel.com/content/www/us/en/products/details/nuc.html -
Thanks jagabo for your suggestion.
I just got back from a computer repair shop to see what if they had anything neat for sale. I ran across a Dell OptiPlex 7050. It's a little bit bigger than a HDD which would be perfect. I guess these are mainly for businesses like hospitals etc, but as far as physical space goes it's prefect. I'll get a hub to share my accessories and use this for internet-only and keep the Win 10 OS computer for capturing. -
I have VirtualDub 2 64 & 32 bit and an old version of VirtualDub and non worked after the latest update, until I did a restore.
Hi Alwyn. Yes I did download 1.9.11. A few months ago I posted a similar thread about Win 10 updates, and the loss of V Dub for capture and you recommended this version of V Dub. After the latest update, even deleting and re-installing did not do the trick. I had to restore to an earlier date. But it took me hours to finally come to the realization of restoring. I've had enough of Win 10's updates.
My Win version is 21H1 as well. I don't understand how re-installing 1.9.11 still wouldn't allow me to capture. -
Windows 10.
If it hurts when you do that, stop doing that. -
Hi!
Have you tried to use VLC to capture ?
It works but you certainly need to try. First try to tet your capture device with VLC to see if your equipement works.
If it works with VLC then it should work with any other software. You can also try AMAREC or the software provided with your capture device.
As for Virtualdub, try with a portable version to see if this can fix something. May be there is something inside the Regedit that must be removed. please be very carefull with that!
May be you shoud delete some of the register keys related to Virtualdub in Regedit, but please be very carefull with what you do. Only do it if you know what you are doing. -
Windows 10 and 11 both capture fine for me. It all depends on your capture device and capture software, I use OBS to do my captures. I'm primarily capturing via a HDMI to USB 3.1 adaptor connected to a ROKU 3, 1920 x 1080 P, works perfectly. I don't capture analog anything anymore.
It's not important the problem be solved, only that the blame for the mistake is assigned correctly -
@Hunk91: No I haven't tried VLC to capture. I thought that program only played files. Does it have the option for lossless video and audio capture? I took Alwyn's suggestion and downloaded version 1.9.11, but again I can't capture after Windows 10 updates. I just turned off the update option in Service.msc and plan on buying a different pc just for internet, and using the current tower pc for capturing-only. If I delete the wrong register keys related to VirtudalDub, I can always re-install correct?
@sum_guy: my capture card is Osprey 827e. I use VirtualDub for capture because the program that comes with the card only allows for lossy caps. All I capture is analog. For editing from dvd/BD I use FAB to rip then import the files in Vegas for editing.
Anyone know why even when I re-install VirtualDub I still can't capture? Only trick that words is restoring to an older date. -
VLC can capture (I tried it a long time ago) but I don't remember if it allows using something other than its own codecs. It uses DirectShow "pin numbers" to select input connections, Graph Studio is another option that I know allows lossless capture using DirectShow but it isn't easy to figure out what to do on your own and it often requires a lot of trial and error to get a working filter graph.
I don't know if it applies to your situation but jagabo wrote in another thread that Windows 10 sometimes blocks access to capture devices as if they were cameras. It is necessary to give apps access to cameras in the Privacy Settings to fix the problem.Last edited by usually_quiet; 11th Nov 2021 at 17:37.
Thanks usually_quiet. I did try to use AmarecTV a few months ago when I lost the ability to capture with VirtualDub. I couldn't figure it out so if Graph Studio isn't any easier, I probably won't be able to use that either. Luckily a system restore allowed me to capture again.
I'll check into the possibility of Privacy Settings in the camera app.
PAL compatible device for standalone vhs capture (no pc)
By superduck in forum CapturingReplies: 7Last Post: 17th May 2021, 17:42 -
Software to capture analog video with Terratec Cinergy HTC USB XS in Win 10
By fltk10 in forum CapturingReplies: 4Last Post: 6th Mar 2021, 14:46 -
Unable to capture using Pinnacle + Scenalyzer + Win 10
By VideoBurger in forum CapturingReplies: 19Last Post: 18th Jun 2020, 22:47 -
Automatically stop VHS capture (Win 8.1 pro64bit, VDub 1.10.4,Diamnd VC500)
By xenakis in forum Video ConversionReplies: 28Last Post: 11th Jan 2020, 10:08 -
Lost VirtualDub capture preview after spring 2018 win 10 update
By mtamimi in forum CapturingReplies: 25Last Post: 23rd Nov 2018, 06:35
