Outside VirtualDub I use OBS Studio to capture directly to HEVC using nVidia CUDA hardware acceleration (HEVC NVEnc codec). It is that fast it never drops any frames, it encodes HEVC in realtime. Of course to get the best possible quality I set the bitrate at 10000K for 1080p or at 4000K for 576p (PAL). Too bad VirtualDub doesn't support CUDA. If you know of any plugin or VFW codec to support CUDA in VirtualDub, please post download link! Thanks!
Results 31 to 33 of 33
SD PAL capture has always been 72x576 for capturing some people do upscale in software for YouTube because it fills the YouTube video player and I think YouTube give it more bitrate.
I think it's because HDMI source has a different resolution that's why you are getting the blackbars or its not capturing at full resolution, if you are getting 732x566 that could mean some of the picture is missing
[QUOTE=spapakons;2748223]
The default setting in logoaway filter is "UGLARM" which blurs the logo area a lot. I discovered that the XY setting almost makes the logo invisible, provided the selected filter area overlaps with all the logo area.
[\QUOTE]
I haven't used it that much to be honest when I have it has crashed alot I was thinking are the crashes damaging my computer
It crashes and says something about Virtualdub memory if I'm not mistaken.
I haven't got as far as you have all I've done is taken opened the screenshot in paint full paint over it in red and then insert that in logo away, but it for it to work you need to give accurate measurements of the logo in terms of logo size otherwise it will blur the wrong area, I find it difficult to use its an old filter that has not be updated I think the one available is a beta version that's why it crashes
I will have to play around with it but from what I understand it's also down to what kind of logo it is if it's a watermark it will be easier to remove if it's a solid logo then it will be difficult.
Yes I know what you mean I hate those announcement logos during a show, in more recent times channels now have a news ticker at the bottom of the screen .
After logoaway I just save as avi with lossless compression, if I need to save it .mp4 I de-interlace and save h264 in Hybrid -
I have logoaway version 4.01, certainly not Beta version.
Find it here: https://www.videohelp.com/software/Virtualdub-Logoaway-filter.
No need to save to a lossless format. If you set a very high bitrate in x265vfw, such as 4000K for 720x576, it is almost lossless. For comparison 1000K in Divx (aka h.263 variant) is as good as MPEG 2 at 6000K+, AVC (aka h.264) is much better at 1000K and HEVC (aka h.265) is much more better than AVC at 1000K. So HEVC at 4000K is almost lossless and gives a much smaller file size than using huffyuv or lagarith. Just saying.
Save capture settings Virtualdub 1.9?
By hpcampr in forum Capturing and VCRReplies: 4Last Post: 7th Feb 2022, 16:40 -
missing codec AVC1 in VirtualDub
By KneeRow in forum Video ConversionReplies: 3Last Post: 15th Mar 2020, 08:23 -
Edit video files in HEVC h.265 codec 60fps & to save in original format
By Wilson Lee in forum EditingReplies: 2Last Post: 27th Nov 2018, 05:24 -
where the HUFFYUV codec save it's configuration?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2018, 09:27 -
Ut Codec/Virtualdub/VHS Capture Questions
By CountChocula in forum Capturing and VCRReplies: 8Last Post: 8th Jan 2018, 04:35
