With youtube-dl I can issue the following command and it starts downloading from the stream:
It continues running until I stop it with Ctrl-C at which point it cleans up the .part file to .mp4Code:youtube-dl -f hls-1180 -o yttest.mp4 https://somestreamurl/
Edit: Or actually in newer versions it just stops, but the part file is a valid mp4 so renaming it by removing the .part extension makes it
a good mp4.
But when I try this instead:
then the download stops by itself after only a few seconds leaving a very short file.Code:yt-dlp -f hls-1180 -o yttest.mp4 https://somestreamurl/
I thought they would work approximately the same but this is a very bi difference...
Results 1 to 10 of 10
Did not work!
The command should run continuously until stopped with Ctrl-C but it stops by itself after downloading 58 seconds of video.Code:yt-dlp --hls-prefer-native -f hls-1180 -o ytdlp-test.mp4 https://xxxxxxxxxxx.com/
If using youtube-dl instead this is what happens. -
Please note that the difference between youtube-dl and yt-dlp concering the donload of a running stream is thet youtube-dl starts at current time and records the stream as it is received.
The way the yt-dlp seems to work is that it finds the latest chunk of the video stream and downloads that and then exits just as if the video url pointed to a fixed size video file rather than a live stream.
So the operation is definitely different, but the way youtube-dl works surely seems to be the best one of the two.
I do not need to use any of the options you suggest with youtube-dl at all, it just needs the format specifier (if "best" does not fit the bill"), the output file name and the URL.
The only reason I am asking this is that I saw in another thread a reference to the yt-dlp as the "successor" of youtube-dl and I hoped they would have added a built-in timeout argument so I could use that rather than the Linux timeout wrapper to get the video length I want (1 hour mostly).
But it seems not to be the case so I will probably drop this and continue using youtube-dl instead. -
youtube-dl is dead in the water with severe throttling issues just one of many issues raised and not addressed by the devps since their last activity in June.
yt-dlp is definitely the way to go over youtube-dl with a very active discord server for help (yt-dlp-help channel) where you can ask for assistance and get answered in seconds. The developer himself is active on there daily too.
https://discord.gg/u9XrQgJU
For live stream downloading I would prefer streamlink - the installer needs double clicking to install it, unlike youtube-dl and yt-dlp. You then call it from a cmd prompt in a similar way though.
If its a HLS stream, streamlink can be halted after a set period with
Code:streamlink --hls-duration 01:00:00 "url" best -o output.ts
Do you mean that youtube-dl is no longer maintained?
When you say "channel" do you mean some kind of social media? If yes then I am not interested, never going to use because of all the harm SM has done to society.yt-dlp is definitely the way to go over youtube-dl with a very active discord server for help (yt-dlp-help channel) where you can ask for assistance and get answered in seconds. The developer himself is active on there daily too.
How do you "double-click" in a server setting where only ssh access to the command prompt is possible?For live stream downloading I would prefer streamlink - the installer needs double clicking to install it, unlike youtube-dl and yt-dlp. You then call it from a cmd prompt in a similar way though.
Or is Streamlink only available on a desktop system?
Mine is a server.
I can test this too provided it can run on a server.If its a HLS stream, streamlink can be halted after a set period with
youtube-dl is dead from june 21. now have mod version of this, yt-dlp indeed.
and for channel on discord is a live chat, more user, including developer and your staff.
is faster to enter and see it than talk about it here ... -
Yes.
You are currently using social media.
Use the portable version then.
https://streamlink.github.io/install.html#windows-portable-version -
I tried the discord which is a live stream of comment so it is hard to find old questions of the same thing...
But I asked and got this solution, which fits my use case:
The -S argument gives me the format 500 or lower (I want 480)Code:yt-dlp -S 'res:500' --downloader ffmpeg --downloader-args "ffmpeg:-t 180" -o testingytdlp-180.mp4 https://hiddenurl.com
The --downloader ffmpeg argument tells yt-dlp to use ffmpeg, which apparently youtube-dl does by default
The --downloader-args "ffmpeg:-t 180" argument sends the timeout to ffmpeg.
In the end this then works to get the resolution and the duration I want and it is done using yt-dlp!
Retrieve video from camcorder / SD card writing error
By funlul in forum Newbie / General discussionsReplies: 6Last Post: 26th Apr 2019, 20:08 -
Retrieve subtitle file embedded in an MP4 video
By kasfig in forum SubtitleReplies: 5Last Post: 20th Feb 2019, 22:27 -
How to retrieve stream offsets?
By CryGuy in forum ProgrammingReplies: 9Last Post: 25th Jan 2019, 07:24 -
Failed to retrieve audio, aborted with BD Rebuilder v.0.60.02
By zapaptoroto in forum Newbie / General discussionsReplies: 0Last Post: 11th Oct 2018, 18:17 -
Retrieve rtmp link from octoshape
By Othmane in forum Video Streaming DownloadingReplies: 0Last Post: 19th Dec 2016, 21:42
