Help,
i have downloaded some movies and converted them to a vcd for my eldest son to watch on his stand alone dvd player,no problem.But now my youngest son wants to watch the same movies on his video,is there a way to transfer the movies to vhs.I posted the question the other day and somebody said to simply connect the video and dvd together via scart leads,this i tried,and yes it did copy the vcd but the quality was very poor.Have i connected the two correctly or is there a way to do the vhs straight from my hardrive,if this is the case what harware and software do i need?.
Please help the kids are killing each other!.
Could somebody help
Should this question be in the newbie section or can anybody help -
I've got the same problem. Now that I'm getting used to doing VCD, I'm trying to figure out what is going to be a reasonable way to get back out to VHS. Maybe someone has some Ideas for hardware, software or even some other sites that might be of some help.
Hey! I don't know if I'm getting smarter or dumber, but, I just read a post in the newbie section a little while ago about recording from your DVD player through the VCR (which is recording) to your tv, which is monitoring. If it's any more complicated than that, I think someone will jump on us shortly.
you should be able to plug your video out/audio out from your dvd player into your VHS line in and hit record.
VCD doesn't have macrovision, so you won't have to worry about that causing you problems. -
Thanks for confirming that. You just helped me solve a major crisis with a really important project.
vhs cassette not sitting down one side in vhs recorder ?
By oldfellow in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2012, 16:23 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 09:19
