  1. could someone please tell me what the valid resolution size is to be able to convert mpeg to bin (to burn it onto a CD-ROM)? thanx
  2. Forget the bin just burn the mpeg in nero. Just select vcd for mpeg1 or svcd if you have a mpeg2. Thats it.
    Feb 2001
    Berlin, Germany
    I think MPEG-2 allows up to 1920 x 1080 pixels. Every resolution (both width and height should be a multiple of 16) is a "valid" resolution if you burn to CD-ROM. If you are aiming for VCD, SVCD or DVD, you should have a look at the "what is ..." section.
    VCD: 352 x 240 / 288
    SVCD: 480 x 480 / 576
    DVD: 720 x 480 / 576
  4. thanx, I also have a couple more questions:
    1: when I play the burnt VCD in a DVD player does it go 'full screen'?
    2: can I play a burnt VCD on a playstation2?
    3: when burning with Nero, I select to create a movie cd and then a couple of folders are in a window and there is another window with some tabs like 'Track' 'Lenght' etc. When I add a file to that window, as I would be supposed to, it says 'Track #2'. Is this normal?
    thank you for your time
  5. dammit, why does'nt anyone ever awnser in my posts? I really want to have the anwser.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
