Hello!
IS AI colorization possible nowadays?
Even 1-2 years age, guys from Videohelp told , that it is a lot of manual handwork....
A perfect example for AI colorization:
Worth to watch and listen the whole clip:
https://www.youtube.com/watch?v=vDHVPQwhqk8
The editor also used AI to increase the resolution of the original clip.
The technique may be useful for some things -- but that clip is a serious desecration of a lot of hard work by a lot of talented people.
Reminds me of this:
[Attachment 61577 - Click to enlarge] -
They used custom-built color and segmenting tools along with standard segmented in-painting of the chroma - MANUALLY - using stock layered compositing tools.
Where AI is used to good effect here is in the tracking of similar segments in time, the recognition of segments and their boundaries.
The "automatic" colorizing processes, whether traditional or AI, are still crap.
And NO, even that manually converted example is not even close to perfect.
Scott -
My first attempt at colourising Beatles live performance (EDIT: STILL PHOTOGRAPH) in NY looks better than anything AI can pull of. And believe me, that colourisation was crap..
Video Colorization AI (PC Software) Question
By magnu in forum RestorationReplies: 12Last Post: 29th May 2022, 19:33 -
What's the best way to convert Variable to Constant Framerate nowadays?
By Dagger7 in forum Video ConversionReplies: 3Last Post: 2nd Oct 2021, 14:31 -
1920x1080 - is it at all relevant if NTSC or PAL nowadays?
By larioso in forum EditingReplies: 20Last Post: 18th Jan 2017, 08:53 -
What codecs are needed nowadays???
By adrian2055 in forum Software PlayingReplies: 12Last Post: 16th Jan 2017, 16:07
