Dears,
following my other post here
I would like to still understand how to extract only audio track from DVD movie without any degradation in terms of quality, size or avoid re-encoding to other video formats and then extracting audio part, etc. In my other post where i was unsuccessfully looking for tool which can do the job in macOS.
Now i have decided to try to look for a tool under WindowsOS.
One recommendation was to try "Pgcdemux" (thanks to ProWo), It did the job, however all three existing audio tracks from DVD had same AC3 file size, odd.
Meanwhile i have tried also to load the DVD vob files into Audacity, you can load only one VOB file, but you can save into AC3. At the end you have to join all AC3 from separate VOBs. What is odd, that the final AC3 file size is very different from the final AC3 file size from Pgcdemux tool.
Based on this findings i am not 100% convinced that one or other software is doing it right.
Please advice, or better enlight me.
Kind Regards,
VLP
				Results 1 to 10 of 10
	There were Three languages in total
 1) Language A - 1.0 = 163MB AC3
 2) Language A - 2.0 = 163MB AC3
 3) Language B - 2.0 = 163MB AC3
 Why all of them had exact same file size, while each of them is different quality or language
 example:
 i was expecting something like
 1) Language A - 1.0 = 120 MB AC3
 2) Language A - 2.0 = 157 MB AC3
 3) Language B - 2.0 = 163 MB AC3
	Well you can inspect the files using mediainfo.
 But I suspect that each file has the same bitrate. Filesize = runlength * bitrate
 Typically you get two types of audio. A LPCM track which will be a significantly larger size due to the bitrate and an ac3 track which is what you see here.
	i am sorry you were right! i Moved one of the VOB into mediainfo:
 Also i have went and opened other DVD9 and it had different results. So it seems i should stick with Pgcdemux
 So, i am sorry for my own mistake. I wanted to have it right
 General
 Complete name : /VIDEO_TS/VTS_01_1.VOB
 Format : MPEG-PS
 File size : 1 000 MiB
 Duration : 16 min 20 s
 Overall bit rate : 8 559 kb/s
 Video
 Format : MPEG Video
 Format version : Version 2
 Format profile : Main@Main
 Format settings : CustomMatrix / BVOP
 Format settings, BVOP : Yes
 Format settings, Matrix : Custom
 Format settings, GOP : Variable
 Bit rate mode : Variable
 Bit rate : 7 813 kb/s
 Maximum bit rate : 9 800 kb/s
 Width : 720 pixels
 Height : 576 pixels
 Display aspect ratio : 4:3
 Frame rate : 25.000 FPS
 Standard : PAL
 Color space : YUV
 Chroma subsampling : 4:2:0
 Bit depth : 8 bits
 Scan type : Progressive
 Scan order : Top Field First
 Compression mode : Lossy
 Bits/(Pixel*Frame) : 0.754
 Time code of first frame : 00:59:59:00
 Time code source : Group of pictures header
 Stream size : 913 MiB (91%)
 Audio #1
 ID : 189 (0xBD)-128 (0x80)
 Format : AC-3
 Format/Info : Audio Coding 3
 Commercial name : Dolby Digital
 Muxing mode : DVD-Video
 Bit rate mode : Constant
 Bit rate : 192 kb/s
 Channel(s) : 2 channels
 Channel layout : L R
 Sampling rate : 48.0 kHz
 Frame rate : 31.250 FPS (1536 SPF)
 Stream size : 22.4 MiB (2%)
 Service kind : Complete Main
 Audio #2
 ID : 189 (0xBD)-129 (0x81)
 Format : AC-3
 Format settings : Dolby Surround
 Bit rate : 192 kb/s
 Audio #3
 ID : 189 (0xBD)-130 (0x82)
 Format : AC-3
 Bit rate : 192 kb/s
 Text
 ID : 189 (0xBD)-32 (0x20)
 Format : RLE
 Format/Info : Run-length encoding
 Menu
	Also you may find this easier to use than pgcdemux
 https://www.videohelp.com/software/DGMPGDec
  Windows Live Movie Maker - Audio/Video Out of SyncBy JasonQuinn1992 in forum Software PlayingReplies: 2Last Post: 8th Sep 2020, 08:46
  Need help with youtube-dl and extracting the audio only and saving itBy Baby Jay in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2020, 21:34
  Extracting - Exporting Audio Only?By CarpentarMate in forum AudioReplies: 3Last Post: 11th Mar 2019, 03:58
  Extracting and downloading one movie from youtube playlistBy David Banner in forum Video Streaming DownloadingReplies: 3Last Post: 27th May 2018, 16:35
  Windows 10 Movie Maker/DVD FlickBy mjrich01 in forum Newbie / General discussionsReplies: 3Last Post: 26th Dec 2017, 12:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
