Hello, I am capturing some old VHS tapes of mine using my JVC S-VHS, HR-S2902U. I have a Dazzle DVC-100 + Windows 7. I can capture the video just fine, but at some points throughout the video I am getting a very strong curved line distortion at the top of the picture.
That distortion continues and waves back in forth. What do I have to do in order to solve this problem? I've been capturing off and on for the last 20 years or so, and have never once seen that happen before. The only thing different now, is the hardware I use.
https://www.dropbox.com/s/u08mfa1kohtebcs/distortion-curves.avi?dl=1
Results 1 to 9 of 9
Flagging, lineTBC needed (change VCR or add a Panasonic DVD-R to be used in passthrough mode)
Set NR to off, to make it as "transparent" as possible (altough NR will not be completely removed, but it's not an issue).
edit: no special setting for tearing/flagging reduction, just VCR -> ES15 -> capture card (use a S-Video signal chain if available)Last edited by lollo; 31st Oct 2021 at 04:35.
I just got the unit today, the DMR-ES15. Unfortunately it did not come with a remote, so had to go out and buy a universal remote, which seems to work well enough.
The issue I'm having is the following. It doesn't seem to want to stay at the menu screen for longer than a few seconds when I have the tray open or closed.
Other thing being, is how do I get to the menu to turn the settings you recommended on/off? Thank you! -
Capturing VHS With D-VHS Deck MPEG-2
By dellsam34 in forum Capturing and VCRReplies: 13Last Post: 19th Jan 2025, 14:30 -
Problem capturing audio with some Hi-Fi vhs tapes
By Altruo in forum AudioReplies: 5Last Post: 23rd Apr 2021, 19:05 -
Capturing Super VHS, VHS, and MiniDV simultaneously
By cricchio31 in forum Capturing and VCRReplies: 4Last Post: 31st Dec 2020, 14:07 -
Capturing VHS with Mencoder, red saturation problem
By the98 in forum Capturing and VCRReplies: 10Last Post: 7th Jan 2020, 08:41 -
VHS to PC capturing problem
By Creepy108 in forum Capturing and VCRReplies: 1Last Post: 8th Aug 2017, 18:54
