Results 1 to 17 of 17
  1. is it possible to find MPD link and Widevine key using youtube-dll and python? normally i inspect mpd and Widevine key from browser manually, but looking for some way that my script find it automatically,
    hope some guru help me with this if this is possible.
  2. yes, it is possible.
    need yt-dlp, ffmpeg, aria2c, mp4decrypt, mkvmerge, mp4dump.
    and one py script to start project and to modify. each streaming site require specific py script. isn't general rule.
    but there are several things to edit, and if you hope someone here will tell you how to do it, you just waste your time...
  3. Thanks @lomero
    Im already using a py script, where i only have to input mpd link and widevine key and script download, decrypt and merge into mp4 file automatically, now im looking for to get mpd link and widevine key from video url, (normally i get them from browser inspect), there should be a way to gather them in py script, this help needed
  4. If you're looking for a 1-click solution then purchase Anystream.
    Even with a custom py script I can assure you there is no single solution for every site. Due to some sites using multi parts. Other sites using a different key per login. Other sites using different keys for video and audio. Etc, etc.
    Whatever script you have, or write for yourself will always need some sort of manual input at some stage of the process.
    Widevine-dl script will not handle multiple keys so is only any good for single key sites (without modding). It will also not handle sites that split single VODs into multiparts.
  5. thanks for your reply @codehound
    let me make my question in simple words, is there any way to get mpd link via youtube-dll or python?
    Regards
  6. Youtube-dl IS python. It will not DL encrypted dash either. Never has and never will. And is now unsupported since June.
    So if I"ve understood you; you want to amend widevine-dl script to actually gather the mpd url ? And then gather the keys from WV-Guesser and somehow insert those into the script with zero user manual input too ?
  7. Originally Posted by codehound View Post
    Youtube-dl IS python. It will not DL encrtpted dash either. And is now unsupported since June.
    So if I"ve understood you; you want to amend widevine-dl script to actually gather the mpd url ? And then glean the keys from WVGuesser and somehow insert those into the script with zero user manual input ?
    Exactly
  8. this script can get content keys without needing the extension
    https://github.com/T3rry7f/NoDRM/tree/master/PywidevineX
    you can use it with your scripts and make a script which does not require chrome extension.
    Note: this script works just like wv gusser extension but without needing the browser so it will stop when extension will stop working.
    discord=notaghost9997
  9. how to get license server url?
  10. Developers Tool
  11. nothing there
  12. Always there
    which website?
  13. widevine server: https://cms.35mm.online/umbraco/api/products/83/drm/widevine?platform=BROWSER&type=MOVIE
    playready PSSH: 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
    widevine PSSH: AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEBCZnY OJMl5KghgHhjg3J5RI49yVmwY=
    --key 10999d8389325e4a8218078638372794:bae3384948b221ba2 716819000670eb7
  14. pssh is the server url?
  15. Originally Posted by ploxer View Post
    No, he already told you, this is the "server" url
    pssh is something else
    usually these 2 (pssh and license "server" url) are the things you need, so you can obtain keys.
    and a working cdm too.
    Dec 2022
    Europe
    Could I do a question by PM? I can't get right pssh. It really would be interesting to see how it could be solved.
    Thanks in advance,
    Regards,
    David
