  1. Dears,
    i am sorry for this post, but i am looking for easy to use sw, which can easily extract movie audio track from DVD. I have DVD already in VIDEO_TS folder.
    I think i was able to do this task when i was drag and drop the folder into MKVToolNix, however since some new version i am unable to do this anymore.
    If there is any other tool where i can check the audio and just extract/save it as e.g. AC3 file. That would be nice.
    Note: i am not interested about selecting the audio track and then convert it with video stream in some kind of video file. Just audio
    Kind Regards,
    VLP
  2. Originally Posted by ProWo View Post
    Try Pgcdemux
    Thank you for very quick answer. I will try. Thank you
    Btw: if you know more , please do not hesitate. Mac friendly is also welcomed
  3. I'm a Super Moderator johns0's Avatar
    canada
    Thread moved to the mac forum where you can get more help.
  4. mplayer/mencoder based tools should be be able to extract audio from unencrypted DVDs
    users currently on my ignore list: deadrats, Stears555
