For a personal project, I'm making a 100-hour-long audio file that will loop perfectly. I don't feel like explaining why, it doesn't matter. What I've been looking for is an audio codec/file format that is lossless or audibly lossless and has no file size limit or length limit. I WOULD use Google to search for this info, however searching "filetypegoeshere length limit" gives me pages and pages of online audio converters rather than the information I'm looking for. I even looked on Wikipedia and found nothing. Is there some kind of knowledge base for this kind of thing, like a website that has everything you could ever want to know about every single audio codec/file format? It seems like Google is intentionally censoring this information for some reason.
For the time being though, is there an audio codec/file format that is lossless or audibly lossless and has no file size limit or length limit?
Results 1 to 9 of 9
RF64, the 64bit successor to WAV, has a max filesize in the exabytes.
My calculation of what is necessary for 100 hrs is ~64GB (16bit, 48kHz,stereo). Doable.
For looping, I have found it appears more seamless when you do the loop crossfade in the MIDDLE of the clip, with the ends cut at the same point. The loop crossfade is best done on a section that is rhythmic enough to match the waveforms down to the sample, and the waveforms of both ending and beginning sections have identical trajectories. IOW, no abrupt transitions in the progression of samples. Also be mindful of bkgd elements, especially ambience, as it is noticeable if a reverb tail doesn't decay normally all the way.
Even if/when you create this, you may have issues with players, as some try to cache the entirety of the clip in memory, and some have issues counting beyond 24 hours. And not all players do loops seamlessly, especially when the file is long/large.
ScottLast edited by Cornucopia; 28th Oct 2021 at 14:52.
RF64, I've never heard of it. Can foobar2000/Audacity convert to it? If not, is there a plugin for it? I've not seen this in any tool. I don't need segments to loop, the entire thing will be a perfect loop, so that's not a problem.
I just created a 126GB, 183 hour, mka file with stereo flac compresssed audio using ffmpeg:
Code:General Unique ID : 226358058694959593151823089436959757486 (0xAA4AF9F160FADE53DBB675455FF8D4AE) Complete name : E:\Temp\output.mka Format : Matroska Format version : Version 4 File size : 127 GiB Duration : 183 h Overall bit rate mode : Variable Overall bit rate : 1 646 kb/s Writing application : Lavf58.76.100 Writing library : Lavf58.76.100 ErrorDetectionType : Per level 1 Audio ID : 1 Format : FLAC Format/Info : Free Lossless Audio Codec Codec ID : A_FLAC Duration : 183 h Bit rate mode : Variable Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Bit depth : 24 bits Compression mode : Lossless Writing library : Lavc58.134.100 flac Default : Yes Forced : No DURATION : 183:23:48.388000000
And similarly large files are fine with uncompressed PCM in MKV, and AVI.Last edited by jagabo; 28th Oct 2021 at 20:19.
You can disable the automagic updates in the Preferences applet, besides blocking Audacity with a firewall.
But if your paranoia is huger than mineyou could give a try to this fork:
https://github.com/SartoxSoftware/audacium/releases/tag/18fbae6"Like this facility, I don't exist."
Best Lossless Codec to Pass AVI Between Different Video Editors on Windows?
By pone44 in forum EditingReplies: 6Last Post: 18th Sep 2018, 13:46 -
Is there an Avisynth Lossless Video Codec that uses lower bitrate for 720p?
By VideoFanatic in forum Video ConversionReplies: 7Last Post: 17th Apr 2018, 19:44 -
Lossless audio compression codec for VirtualDub?
By synnchan in forum Newbie / General discussionsReplies: 4Last Post: 20th Jan 2018, 15:15 -
Adobe Premiere converts YUV to RGB when using a lossless codec
By Hypersonic1 in forum EditingReplies: 6Last Post: 1st Dec 2017, 18:12 -
x264vwf filesize (H264 rendering KBPS and filesize insane)
By Joris Ceoen in forum EditingReplies: 11Last Post: 2nd Apr 2017, 09:49
