    Aug 2009
    New Zealand
    ive been testing out audio bitrates and codecs and found opus to be the best at this bitrate my ears cant tell the difference when compered to 320kbps mp3/aac
    i just have 1 problem when i rip a cd to opus meda info in media player classic shows the khz as 44.1khz same as what the original cd is but vlc player and the app on my phone both say the audio is 48khz
    General
    Complete name : G:\All Time Low\Nothing Personal\04 All Time Low - Lost In Stereo.opus
    Format : Ogg
    File size : 3.98 MiB
    Duration : 3 min 47 s
    Overall bit rate : 133 kb/s
    Album : Nothing Personal
    Album/Performer : All Time Low
    Part : 1
    Part/Total : 1
    Track name : Lost In Stereo
    Track name/Position : 4
    Track name/Total : 12
    Label : Hopeless Records
    Genre : Pop / Rock
    Recorded date : 2009
    Writing application : Opus 1.3.1
    ISRC : USHR20947004
    ENCODER_OPTIONS : --bitrate 120
    Style : Pop Rock / Power Pop / Punk / Pop Punk
    Catalog # : 710
    Source : CD (Lossless)
    Encoded By : dBpoweramp Release 17.4
    Encoder Settings : -bitrate="120"
    AccurateRipResult : AccurateRip: Accurate (confidence 2) [3D071E1E]
    AccurateRipDiscID : 012-00120512-00a952af-8f099f0c-4
    Audio
    Format : Opus
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 44.1 kHz
    Compression mode : Lossy
    Writing library : libopus 1.3-26-ge85ed772, libopusenc 0.2.1-2-g9cb17c6
    so im confused is media info wrong or has it really converted the 44.1khz to 48khz and will there be any problems so far the 2 cds i ripped sound fine without problems
    Mar 2008
    It says sampling rate 44.1 in the report above
    Aug 2009
    New Zealand
    yes but all other programs say it 48khz
  4. Member Cornucopia's Avatar
    Assuming you did NOT do any SRC (sample rate conversion), ALL CD rips would be 44.1kHz, and so would any compressed version from them. So, I must deduce that those other apps are wrong.
    MediaInfo does not do any SRC, it just shows you what the metadata is in the file. Would love to see some of these other apps that are reporting otherwise.
  5. DECEASED
    Jun 2009
    Heaven
    i just have 1 problem when i rip a cd to opus meda info in media player classic shows the khz as 44.1khz same as what the original cd is but vlc player and the app on my phone both say the audio is 48khz.
    From Wikipedia's article about the Opus audio format:
    Opus allows the following bandwidths during encoding. Opus compression does not depend on the input sample rate; timestamps are measured in 48 kHz units even if the full bandwidth is not used. Likewise, the output sample rate may be freely chosen. For example, audio can be input at 16 kHz yet be set to encode only narrowband audio.
    Abbreviation          Audio bandwidth    Effective sample rate
    NB (narrowband)        4 kHz               8 kHz
    MB (medium-band)       6 kHz              12 kHz
    WB (wideband)          8 kHz              16 kHz
    SWB (super-wideband)  12 kHz              24 kHz
    FB (fullband)         20 kHz              48 kHz
    "Programmers are human-shaped machines that transform alcohol into bugs."
  6. Member Cornucopia's Avatar
    Wow.
    This was news to me.
    Reading those docs, it appears Opus applies SRC both on encode and (usually) on decode, And there are also built in lags for that src as well as for packet resiliency, and a few other codec-switching-trick functions.
    This may be cool for some of those features, but the audiophile in me says F**k No! I have so far rarely used the codec family, mainly because I have few hardware devices that support it, but it seriously gives me pause about using it again. I don't want any app applying SRC that isn't fully under my control.
