Results 1 to 24 of 24
  1. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    I have a number of MP4 files. They have chapters. However, there's no chapter at the start of the file, because whoever created them evidently felt that having a chapter marker there was redundant.
    FFMPEG believes otherwise, because this:
    for %F in (*.mp4) do (ffmpeg -i "%F" -acodec copy -vcodec copy -map_chapters 0 "%~nF.mkv")
    results in an MKV file that shifts the first chapter point from wherever it originally was, and puts it at the start. Which basically means that it's deleting that chapter point. All other chapter points seem to be in the correct spot.
    Is there a way to add a chapter point to the start of the mp4 file as part of this batch process, so it all comes out correctly?
  2. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    So I have to do it manually? For all of them? I have over 200 files here...
  3. Then write a script which exports the chapters adds a chapter at 0 and then add the chapters on remuxing back. (or use a program which already does it, my guess is most guis that can use ffmpeg will do it,..)
    users currently on my ignore list: deadrats, Stears555
  4. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    If I knew how to write a script that would do that, I wouldn't be on here asking how to do it...
  5. Probably not really something one would want to do with in a Windows batch script, but should be possible.
    The general steps would be:
    a. extract chapters into a readable file
    b. add chapter at zero if non exists
    c. remux
    May be someone with enough knowledge and motivation will show up (most encoding guis like MeGui, StaxRip, etc. which support batch processing and output to mp4 should do this in the background)
    Cu Selur
    Ps.: Did you try using mkvmerge instead of ffmpeg, iirc. mkvmerge also has no problem with this and it's a command line tool.
  6. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    Wouldn't mkvmerge require having an mkv file to begin with?
    And, again, I have no idea how to go about editing the chapters in an automated way, so simply saying to do that doesn't help me.
  7. Wouldn't mkvmerge require having an mkv file to begin with?
    No, mkvmerge takes lots of different formats as input, but only outputs mkv.
    Feb 2006
    try using the ffmetadata format - https://stackoverflow.com/questions/47415660/how-to-add-chapters-into-mp4-mkv-file-using-ffmpeg
  9. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    Again, that doesn't help with automating the process.
    I tried creating a one-second black video, giving it a chapter right at the start, then using mkvmerge to mux it onto one of the problem mp4 files. It kind of works, the first chapter from the mp4 stays in the correct spot and it adds the chapter from the blank video, but a) they're in separate editions instead of just the one edition and b) when I try to play the output file in VLC it just stays with a black screen and the yellow loading bar trying to load the file.
  10. What do you mean by "they're in separate editions instead of just the one edition" ?
    Got a small sample file which allows to reproduce the problem?
  11. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    When you view them in the MKVToolnix chapter editor, there are two editions in the file. I don't know what an edition is or how it works, though.
  12. okay.
    -> "Got a small sample file which allows to reproduce the problem?"
  13. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    Wait, got it. I was adding rather than appending. If I append the one-second, one-chapter black screen video to the existing problem video, I get a perfectly functional and correctly-chaptered MKV file. Woot.
  14. Have you trief just remuxing with mkvtoolnix and not appending anything? (I think mkvmerge should be able to do this without issues and you could use it in a bash script if you want to.)
  15. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    Well that does work inasmuch as it retains the existing chapter points, but there's still no chapter point at the start of the file, which screws things up.
  16. I thought the issue was that the chapter points were moved,.. "results in an MKV file that shifts the first chapter point from wherever it originally was" -> confused, but it appending worked fine for you okay,...
  17. Not sure if it will help but MKVToolNix has an option called “One chapter for each appended file” in the “Output” tab ; perhaps it would add a chapter point at the beginning of a single input MP4 file, making the rather dirty trick of adding a 1s blank clip unnecessary, although I don't know how it would interact with existing chapters. When you play with MKVTookNix GUI and find an option that works as intended, you can then display the corresponding mkvmerge command line with “Multiplexer” > “Show command line”{*}, and then use that command line directly in a script to batch-process dozens of files in the same way. I tested with a single MP4 file as input, enabling the aforementioned option added this to the command line :
     --chapter-language und --generate-chapters-name-template ^"Chapitre ^<NUM:2^>^" --generate-chapters when-appending
    {*} Disclaimer : I'm using a version from 2019 and it has a rather hectic development rate so it could have changed in the mean (really mean) time.
  18. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    It adds the chapter point at 00:00:00.000, but when you view it in the Toolnix Chapter Editor that's the last chapter on the list. As such, when played back in VLC it shows up as the "last" chapter, which means the entire video is now "Chapter 01" and all the original chapter points are inaccessible.
  19. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    It's possible as a three-step process though:
    mkvmerge -o "%~nF.mkv" --generate-chapters when-appending "%F.mp4"
    mkvextract "%~nF.mkv" chapters --simple "chapters.txt"
    mkvpropedit "%~nF.mkv" --chapters "chapters.txt"
    Now I just need to figure out what to replace ~nF with so it puts things in the correct subfolder, otherwise I'll still have to run it a couple dozen times.
  20. It adds the chapter point at 00:00:00.000, but when you view it in the Toolnix Chapter Editor that's the last chapter on the list. As such, when played back in VLC it shows up as the "last" chapter, which means the entire video is now "Chapter 01" and all the original chapter points are inaccessible.
    Alright then. At least you found a workaround.
    Not sure what you mean here, but you can specify a folder name before the %~nF parameter / argument, and add a suffix after if needed — in this case to specify a different name for each chapter file, based on the MP4 file base name. Also you can run all three commands in a single loop. For instance :
    FOR %%F in (*.mp4) do (
        mkvmerge -o ".\MKV\%%~nF.mkv" --generate-chapters when-appending "%%F.mp4"
        mkvextract ".\MKV\%%~nF.mkv" chapters --simple "%%~nF - chapters.txt"
        mkvpropedit ".\MKV\%%~nF.mkv" --chapters "%%~nF - chapters.txt"
    (This should work as a .bat script, located in the same folder as the MP4 files ; if typing the commands from the command prompt only one “%” percent sign should be used.)
    (The “.” in the example above means “the current folder”, the one where the script file is located and executed from.)
  21. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    I mean I have the video files in subfolders, so if I want to run it once, I need to save them as %~dpnF.mkv not just %~nF.mkv.
  22. Then you could use FOR /R {*}.
    FOR /R "E:\name of\the parent folder" %%F in (*.mp4) DO ...
    {*} I like the random quote they put in there :
    “Just think how happy you would be if you lost everything you have right now, and then got it back again.” ~ Frances Rodman
  23. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    Yes, I know, but my point is if I do that, and save them as %~nF.mkv, they all get saved into whatever folder the command line is running from, rather than the folder the original file was in. They need to be saved as %~dpnF.mkv to end up next to the originals.
