I searched the forum but I didn't find a clear answer. Sorry if I missed something. I'm lowering the framerates of some 60 fps clips to 24 fps using hevc(h.265). 60 fps clips are at 10 mbps vbr. How low of a bitrate can I go for the 24 fps without losing quality? Thank you.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
I understand it perfectly.
How much this describes "video content" or "codec", or "quality"!?
Answer by my understanding of "equally the same quality": Bitrate would be only higher, probably ~10 times.
For answer to your probable understanding of "equally the same quality": Look at the last sentence in my previous post. -
If there is ANY correspondence between framerate and bitrate (very rarely), it is that it is most likely NOT linear, or if it is, it isn't a 1:1 45degree diagonal line. Higher and higher framerates have successively less and less differences between frames, so the delta becomes less, so the amount of ADDITIONAL bitrate to accommodate those minor changes becomes less and less. Diminishing compounded investment yields bigger returns.
The converse should also be true: lowering the framerate by HALF (e.g. from 60 to 30) means each change is a bigger change (1/60th sec later vs 1/30th sec later), so more relative residual bitrate must be retained in order to retain equivalent quality.
So, for example, source 60fps @ 60mbps, dropping to 30fps might take 32 or 35 or 40 mbps vs your presumed expectation of 30mbps. All other things being equal (especially perceived quality), which they probably aren't since one is a later generation than the other.
This pretty well holds true regardless of codec (assuming you are using the same codec, and encoder in the comparison).
ScottLast edited by Cornucopia; 26th Oct 2021 at 00:20.
MKVToolnix causes file corruption in second half
By green81 in forum Video ConversionReplies: 5Last Post: 16th Sep 2021, 04:24 -
bd3d2mk3d and half-SBS or half-tab issue
By Scarredjoker in forum Blu-ray RippingReplies: 81Last Post: 30th Nov 2019, 06:23 -
HEVC and H264 bitrate/quality equivalency
By philvideofilm in forum Video ConversionReplies: 15Last Post: 29th Sep 2017, 18:41 -
Only half the audio loads in premiere pro
By The_Sociopath in forum Newbie / General discussionsReplies: 16Last Post: 27th Jan 2017, 20:46 -
Video Quality Testing of HEVC Compresssion. H265 vs H264: 50% bitrate saved
By Baldrick in forum Latest Video NewsReplies: 25Last Post: 2nd Jan 2017, 04:38
