Please could somebody help, I have a LG CDRW/DVD combo. I use Power DVD 4, but it will not play back some region DVDs. how can I fix this???
Thanks in advance, Pip
Pip@easy.com
Oh. This really must be the record for grave-digging even if it is the OP who is posting.
Where, I must ask, have you been for the past 16 years ?. Certainly not reading the forum it seems. And you hardly helped your case by not mentioning the model no of the dvd drive.
Does not matter since I suspect you have a RPC 2 drive and that can not be un-locked as RPC 1 drives could. So by reading the forum you would have gleaned that your best solution would be the free version of dvdpasskey (defaults to free just for dvd after the trial period) -
Yes. There is no way to prevent PowerDVD from setting the region code for DVD and Blu-ray drives and checking DVDs against it. DVDFab Passkey gets around region code enforcement by making DVDs appear to be region free/all-region. DVDFab Passkey also decrypts on the fly and can allows older versions of PowerDVD to work with new movies that cannot otherwise be played.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Thanks for the swiftish replies, evryone.
I'll look at all you suggested. I'll let you know how I get on in the next decade or so.
Cheers. -
The point of these forums is that people give their time to actually help.
The nature of your response does not believe that you seriously resurrected the topic to get the help that the original Q. deserved >> I can not speak of 2002 since I was not around here back then.
If I am wrong then the least you can do is apologise for that last post.
How do I set a LG DVT499H into multiregion?
By ELCROWLEY in forum DVD & Blu-ray PlayersReplies: 2Last Post: 4th Aug 2009, 13:24 -
Multiregion code for LG DK7821P
By ieh4f in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Jul 2008, 16:11 -
LG HT-302SD MultiRegion Hack
By Xqbz23 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 13th Jun 2007, 19:38 -
Multiregion for Sharp DV-SV90S
By PhyRo in forum DVD & Blu-ray PlayersReplies: 13Last Post: 12th Jun 2007, 13:12 -
multiregion hack
By chrissi34 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th Jun 2007, 17:59
