  1. I'm using Windows 10 and have Pismo File Mount Audit Package build 180 installed.
    I'm having an issue registering avfs.dll through Command Prompt. When I enter the command pfm register c:\windows\avfs.dll it'll then say Registering formatter "pfm register C:\Windows\System32\avfs.dll". with nothing happening. Then I tried the command regsvr32 avfs.dll by placing avfs.dll in the System32 folder and got this error message
    The module "avfs.dll" was loaded but the entry point
    DllRegisterServer was not found.
    Make sure that "avfs.dll" is a valid DLL or OCX file and then try
    again.
    Am I using the wrong command? Did I place avfs.dll in the wrong file location? Or is it something else I'm doing wrong?
  2. On my Windows 7 system, there is a 44KB avfs.exe file in the Windows directory (C:\Windows\avfs.exe). I don't see any avfs.dll file.
    I installed it years ago and don't remember the specifics.
