Let's see if tomorrow, 11-11, I get an extra discount on that Acasis.
Results 31 to 36 of 36
A simple solution but it is not true stereo, it's just duplicating the mono audio track.
This can be done with FFMPEG :
input.avi is the captured video file via Virtual Dub and output.avi the file created by FFMPEG with the mono audio track duplicated.ffmpeg -i input.avi -c:v copy -ac 2 -acodec pcm_16le output.aviLast edited by Hunk91; 10th Nov 2021 at 16:20.
Duplicating the mono track is not the same, even if you edit the new track a few milliseconds backwards. What was called simulated stereo.
I am trusting I can feed a stereo track from the source in the device line input, which should be in sync with the video.
Having a stereo line input I can even add an HDMI mini-DAC in the middle, as I did on my main system before buying the Pioneer receiver. HDMI in/out + RCA out. The sound was great, though stereo. For me stereo is enough, not such a great fan of 5.1.
But all of this would be just a bet. -
Surprise surprise! The Acasis is "no longer available" for the 11/11 sale!
Wanna bet that it will show again after the sale?
Just didn't want to discount it. -
I think I discovered what might have happened: Acasis did release a new model with the same characteristics, including line audio in. Though you can select between two HDMI inputs and outputs.
https://www.aliexpress.com/item/1005002553347440.html?ug_edm_item_id=1005002553347 440&tracelog=rowan&rowan_id1=buyerPayOnlineSuccess ToBuyerV2_1_pt_BR_2021-11-11&rowan_msg_id=1577814165189431$35005803f89f459db cefc69f88d677cc&ck=in_edm_other
It seems better built, but it has no model name. -
Audio from two devices cannot be synched.
By SF01 in forum AudioReplies: 3Last Post: 16th Nov 2019, 15:50 -
Capturing with VDub / compatible devices (VfW drivers) ? Or alternatives..
By benni in forum Capturing and VCRReplies: 5Last Post: 21st May 2018, 05:09 -
UNNECESSARY Video recording framerate limitations
By TechLord in forum Newbie / General discussionsReplies: 50Last Post: 2nd Feb 2018, 21:37 -
Appreciate suggestions devices also capable of capturing/recording BIOS
By vhwul62 in forum Capturing and VCRReplies: 4Last Post: 29th May 2017, 01:08 -
SD analog videotape limitations vs. SD broadcast limitations
By lingyi in forum Newbie / General discussionsReplies: 3Last Post: 14th Jan 2017, 10:51
