  1. EDIT: DAUM Potplayer
    Large video has black bars on left and right side. I want to keep window to only video size, so I set
    Right click -> Window Size -> Fit to video aspect ratio 8
    But this does not persist between video sessions.
    So I go to
    Preferences -> Playback -> Default window size -> Fit to video aspect ratio
    But now the video is tiny, set to like 0.25x video output size
    How to get video to play at '1.0x output size' while making the window automatically fit to video aspect ratio as if I pressed 8?
  2. NVM, found it immediately after!
    Mar 2008
    You responded to your own post with the solution, but in neither post have you identified the software
  4. Originally Posted by davexnet View Post
    Oops, you're right! It was Potplayer
