Hello,
Trying to cut certain JAV movies into single scenes without re-encoding files.
AviDemux software is used [for MP4, MKV] as it's simple and quite reliable and fast.
Only problem noticed that sometimes, when scene got cut by I frames, it happens that start of video being shifted to previous I frame.
1) Is this normal in certain cases and can still occur now and then, or mainly should not happen and I'm doing something wrong.
2) As addition question, is this fine to stop scene on B/P frames instead of I if it looks better ?
Found info somewhere that I-frames are main ones, and these are critical, and if not used at start, will result in artifacts. While for video ending its not quite important to stick to I frames.
avidemux does not distinguish between IDR frames (true keyframes) and "i" frames. ie. If video uses open GOP, you can have problems cutting
In "copy" mode it's not ok . You can only cut on keyframes. The reason is frames can reference other frames (the current frame might rely on information from other frames). If you cut frames that were relied upon, you get decoded garbage for that GOP section. True keyframes have no references from other frames, they are "self sufficient" -
Just adding a visually example of what PoisonDeathRay has explained in detail, using ffprobe to check a video frames can show what is and isn't a key Frame. In the text below obtained from one of my test videoes, Notice around frame 127 shows an 'I' frame but is missing the key frame Indicator '1' showing a '0' instead.
No. pts_time dts_time type Frame#
0 0.000000 0.000000 1 I 0
1 0.033333 0.033333 0 B 3
2 0.066667 0.066667 0 B 2
124 4.133329 4.133329 0 P 121
125 4.166663 4.166663 0 I 127 0 I instead of 1 I
126 4.199996 4.199996 0 B 126
249 8.299992 8.299992 0 P 249
250 8.333325 8.333325 1 I 250
As far as cutting the end of a video, You can cut at a 'P' frame PROVIDED nothing after it must be decoded before it can be displayed. Notice below how FFMpeg (used in a lot of cutting/editting programs) will try to handle this by adding an additional 'P' frame with a longer Presentation Time Stamp(PTS). This normally isn't appareent since it is the last frame of the cut, but if you merging something behind it you will see the frozen frame glitch.
C:\Users\Bud\Desktop\5_0_test.mp4
UnSuccessful Cut at Frame 492
16.233317,B
16.266650,B
16.299984,B
16.333317,P
16.466650,P 0.133333 after preceding frame instead of normal 0.033333
FPS Duration on final frames too large
Decreasing Ending Frame to 491
Successful Cut at Frame 491
16.199984,P
16.233317,B
16.266650,B
16.299984,B
16.333317,P Normal 0.033333 after preceding frame
copying parts from the previous frame to the current one?
By romeo in forum RestorationReplies: 13Last Post: 30th May 2021, 12:57 -
Replace current video frame by duplicate of previous/next with "hot keys"
By semel1 in forum Newbie / General discussionsReplies: 2Last Post: 1st Feb 2021, 12:05 -
Aegisoft: view video frame by frame
By Bonnie25 in forum SubtitleReplies: 1Last Post: 15th May 2019, 18:05 -
Frame Rate, Bitrates ans Frame by frame comparison
By novreis in forum Newbie / General discussionsReplies: 1Last Post: 5th Feb 2018, 17:40 -
Use ffmpeg to replace frame with previous frame if frames are X % different
By dkrichards16 in forum Video ConversionReplies: 0Last Post: 29th Apr 2017, 16:27
