I have two subtitles files, one from RedBox, and one from Roku.
They say TTML in them and Subtitle Edit says "HBO Go" Format, but nothing I do will convert it.
I am trying to make either a VTT or SRT so I can use it with ffmpeg.
I tried Subtitle Edit, ttconv, and ttml2ssa, the latter two just crash without even trying.
NOTE: I had to name the files .xml as the system didn't like the .ttml extension.
Subtitle edit will convert them,have you got the latest version?
I am trying it again. It looks like I was two versions behind with 3.6.0.
I am going to try with 3.6.2 and see what happens.
For some reason with 3.6.0, it would say converted but then ffmpeg would only put in like the two few lines as mov_text then stop with any subtitles after that.
EDIT: Wow! I literally just installed 3.6.2 and then did the exact same thing I did with 3.6.0, but instantly the subtitles worked.
I also noticed for some reason, 3.6.0 made the FJ subtitles file 52KB in size but 3.6.2 made the file 47KB.Last edited by RedPenguin; 23rd Oct 2021 at 00:09.
Convert ttml+png to .sub/.idx or .sup with Subtitle Edit
By nzhd in forum SubtitleReplies: 2Last Post: 23rd Apr 2020, 23:17 -
TTML/CC to ass with positions?
By Hakunamatata67 in forum SubtitleReplies: 2Last Post: 25th May 2019, 03:36 -
Colour correction (kind of)
By Marcoh_ in forum RestorationReplies: 7Last Post: 15th Feb 2019, 19:49 -
How to make this kind of effect?
By Dokedos in forum Newbie / General discussionsReplies: 6Last Post: 20th Dec 2018, 10:01 -
TTML subtitles
By vidblue in forum SubtitleReplies: 6Last Post: 19th Jun 2017, 23:05
