I have this card (two DVI-I ports)
https://www.evga.com/products/specs/gpu.aspx?pn=30755FA1-BCB6-43FD-8697-94457FBE97A9
And I want to connect this monitor (two HDMI ports)
https://www.lg.com/us/monitors/lg-32mn60t-b-led-monitor
Am I correct that this cable will do the job?: https://www.ebay.com/itm/384411745779
Thank you!
Yes!
DVI (-D, or the D part of -I) is directly compatible with HDMI (same family of signal protocols). It'll just be without any audio to the TV/Display, since DVI doesn't support audio.
Scott -
The card should have a hdmi connector so you could just use a regular hdmi to hdmi cable.
Yes, the DVI-D single-link male cable end will plug into the video card's DVI-I dial-link female port without problems. The DVI-I dual-link female port on the video card has more holes than are needed for the pins on the DVI-D single-link male cable end.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
DVI-I = DVI-A + DVI-D. 2 independent channels, usually in an either-or setup.
DVI-D (or the Digital side of DVI-I) <--> HDMI just fine.
DVI-A (or the Analog side of DVI-I) <--> VGA just fine.
Just about anything else requires either an active converter box, or it must use a disguised, alt-mode option (like DP, Thunderbolt have, where they piggyback HDMI in their alt mode).
Look at the images of dvi plugs and you can see the differentiation between the 2 subformats (analog and digital) and the 2 link densities (single and dual) and how the I (integrated) tries to accommodate both.
ScottLast edited by Cornucopia; 23rd Oct 2021 at 21:45.
WinXP, upgrade video card to use HD TV as monitor, what to get?
By sdsumike619 in forum ComputerReplies: 6Last Post: 11th Oct 2021, 17:35 -
Cable box > HDMI audio receiver > HDMI splitter > Capture card?
By ArianK in forum AudioReplies: 0Last Post: 6th May 2021, 04:18 -
How to determine if capture card color matrix is correct?
By ENunn in forum Capturing and VCRReplies: 5Last Post: 20th Feb 2021, 15:19 -
Terrible picture problem with new monitor and graphic card
By kodec in forum Newbie / General discussionsReplies: 11Last Post: 17th Jun 2018, 15:46 -
Configuring correct Levels for GPU driver-> HDMI->Monitor
By chummy02 in forum ComputerReplies: 3Last Post: 14th Jul 2017, 16:04
