I was trying to cut a lossless AVI file that I wanted to create clips from but seeking in Virtualdub2 in next to difficult. This isn't the first time this happened but it seems like it really hates big AVI files even when I plan to convert it to MP4. What is going on?! Other programs to not do this but Virtualdub2 does.
According to your specs you have an hp computer and most likely its underpowered and has issues with bigger files and virtualdub2,just use the other app that doesn't have this issue.
Two main possiblities: a missing or damaged keyframe index, or long GOP interframe codecs. For the first, rebuild the index. For the second use shorter GOPs or all I-frames.
In what way is "seeking difficult" ? Did you mean slow or unresponsive ? Or did you mean something else ? Maybe like timeline /playhead /framenumber visibility, or framing/zooming the timeline "granularity"?
What is the lossless compression and settings used ?
What are the "other programs" that do not have seeking problems (I'm assuming on the same file) ?
Another possibility is you're using different decoders for each -
The computer details listed in the OPs profile says his computer has only 4gb if ram, that would be my first guess as to the slow performance.
Using Avisynth+ with Virtualdub2
By stymie in forum Video ConversionReplies: 7Last Post: 5th Feb 2021, 19:17 -
VirtualDub2 does not recognize .AC3 .AAC audio files
By coukou in forum EditingReplies: 15Last Post: 8th Jan 2021, 09:05 -
Virtualdub2 and FFmpeg: How do I convert this code to Virtualdub2?
By Guernsey in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2020, 05:25 -
VirtualDub2 plugins
By foldbck123 in forum Newbie / General discussionsReplies: 14Last Post: 21st Nov 2018, 04:29 -
VirtualDub2 - Encoding MPEG2 Files (bad qualitiy compared to TmpGenc 2.5)
By TJFO in forum Video ConversionReplies: 11Last Post: 15th Aug 2018, 16:59
