Hi all
Came across a free solid link for the US TV channel CMT
Here is the link https://ustvgo.tv/cmt/
I would like to extract the link so I can insert it into my IPTV PVR.
M3U8 sniffer gives me this link https://h2.ustvgo.la/CMT/myStream/chunks.m3u8?nimblesessionid=93672897&wmsAuthSign=c2V...ludXRlcz0yNDA=
It only lasts for a few hours before expiring.
How on earth would I be able to generate a static link, which will work with NextPVR.
If anyone is able to do it for me, then upload the file or playlist needed, I would also be greatly appreciated.
Results 1 to 9 of 9
It plays in VLC here. What I want to know is how he got it. Or what's the URLs for all the other channels.
<edit>
I found you can try different numbers at the end. For example:
http://85.203.33.91/307251114011/307251114011/81060
gives you the Cartoon Network.
</edit>Last edited by jagabo; 15th Oct 2021 at 22:51.
Found the problem! Website seems to block IP addresses - Didn't work with my home IP, didn't work with my US VPN, but when I tried a private VPN of mine it loaded immediately.
What crippled my Internet? Static IP for devices?
By kanamit in forum ComputerReplies: 5Last Post: 28th May 2020, 08:22 -
Downloading from cmt.com once I've signed in
By kevinrm27 in forum Video Streaming DownloadingReplies: 1Last Post: 10th Aug 2017, 21:48 -
Best way to remove static dust?
By Sartyx in forum RestorationReplies: 7Last Post: 10th May 2017, 11:28 -
Video is static on 2nd playthrough
By crispyghost in forum RestorationReplies: 5Last Post: 3rd May 2017, 09:17 -
VHS static
By freedom-strike in forum RestorationReplies: 35Last Post: 18th Nov 2016, 11:32
