Results 1 to 13 of 13
    Oct 2021
    Fremont Calif.
    Ok so I use format factor about 6 mos. ago then my PC crash and lost the program. Grabbed a new format factory program and now it does not fix my MVK files to work in the car like before. When i converted them from MVK large files into MP4 they played great in my cars DVD Kenwood radio. If i recall I did nothing more the click on MP4 then covert. now I do it and it says can not play this file.......Does anyone have any idea what I'm doing wrong. Thanks in advice for the help. Jeff
    Oct 2021
    Fremont Calif.
    >>Bump> Any help Please
    Mar 2008
    Use mediaino (put it in text view for all details) and compare a working with a non-working file
    If you don't see anything obvious, post the results here
    Oct 2021
    Fremont Calif.
    working one
    General
    Complete name : E:\Format Factory Program Movies Car\A.Simple.Plan.1998.1080p.BluRay.X264-AMIABLE.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 4.02 GiB
    Duration : 2 h 1 min
    Overall bit rate : 4 755 kb/s
    Writing application : Lavf58.29.100
    Video
    Format : AVC
    Format profile : High@L4
    Format settings : CABAC / 4 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 4 frames
    Codec ID : avc1
    Bit rate : 4 695 kb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.094
    Stream size : 3.90 GiB (97%)
    Writing library : x264 core 157
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=4695 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Menus : 3
    Codec configuration box : avcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Bit rate mode : Constant
    Bit rate : 128 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 44.1 kHz
    Frame rate : 43.066 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 111 MiB (3%)
    Language : English
    Default : Yes
    Alternate group : 1
    Menus : 3
    Menu #1
    Codec ID : text
    Language : English
    Bit rate mode : CBR
    Menu For : 1,2
    00:00:00.000 : 00:00:00.000
    00:08:54.200 : 00:08:54.200
    00:18:24.770 : 00:18:24.770
    00:27:32.192 : 00:27:32.192
    00:38:44.322 : 00:38:44.322
    00:44:35.673 : 00:44:35.673
    00:49:34.430 : 00:49:34.430
    00:54:03.031 : 00:54:03.031
    01:00:50.438 : 01:00:50.438
    01:19:39.942 : 01:19:39.942
    01:27:59.816 : 01:27:59.816
    01:35:38.274 : 01:35:38.274
    01:40:21.390 : 01:40:21.390
    01:47:27.566 : 01:47:27.566
    01:52:49.763 : 01:52:49.763
    01:55:34.928 : 01:55:34.928
    Menu #2
    non working:
    General
    Complete name : E:\Format Factory Program Movies Car\maybe bad movies\Cry_Macho_2021_2160p_HMAX_WEB-DL_DD5_1_HDR_HEVC-CMRG-xpost (1).mp4
    Format : MPEG-4
    File size : 3.56 GiB
    Duration : 1 h 43 min
    Overall bit rate : 4 910 kb/s
    Video
    Format : AVC
    Format profile : Main@L4
    Format settings : CABAC / 1 Ref Frames
    Format settings, Reference frames : 1 frame
    Codec ID : avc1
    Bit rate mode : Variable
    Bit rate : 4 777 kb/s
    Maximum bit rate : 14.3 Mb/s
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.096
    Stream size : 3.47 GiB (97%)
    Audio
    Format : AAC LC
    Duration_LastFrame : -12 ms
    Bit rate : 128 kb/s
    Stream size : 95.4 MiB (3%)
    Title : English
    Language : English
    Default : Yes
    Alternate group : 1
    Oct 2021
    Fremont Calif.
    davexnet,
    I see stuff that looks differnt not sure if it matters or not and if so how would I change the sluff in format factory
    Mar 2008
    I would do a test encode, perhaps a few minutes, set the AVC/H.264 encoder to use preset Medium, bitrate control CRF 18
    and see if that works
    Oct 2021
    Fremont Calif.
    I might need a little hand hold here until I understand what going on I really appreciate the help. So I only see AVC/H.264 the rest I don't see. Jeff
Name:	10-14-2021 8-37-49 PM.jpg
    Mar 2008
    Unfortunately I do not FF installed, so I cannot advise further. How do you play these files in the car, USB stick?
    If you want something simple for this conversion, I'd recommend FFmpeg and simple command line
    which you can put in a batch file so you just drag your source onto it and it will start
  9. You could also try to change the profile level (from 4 to 3) on the non working video.
    No recode is needed, so there is no quality loss.
    Use clever FFmpeg-GUI.
    [Attachment 61291 - Click to enlarge]
    Oct 2021
    Fremont Calif.
    Yes I use a USB stick ok I will try that. Thanks
    Prowo I will try this also and report back. Thanks
    Oct 2021
    Fremont Calif.
    Prowo,
    it keeps trying to open it with adobe how else can I try to get this program. Thanks Jeff
    got it to d/l now it says this???Image
    [Attachment 61292 - Click to enlarge]
  12. Follow the indications.
    Download a ffmpeg static build for your system (x86 or x64) (you can click the link after download from here).
    Extract the downloaded file to any location you want on your computer. Then point to the folder that contains ffmpeg.exe, ffprobe.exe and ffplay.exe.
    That's all.
    You have to do this only one time.
    Oct 2021
    Fremont Calif.
    I would like to thank everyone who helped me get this figured out. ProWo That's a great program and it works flawlessly. Thanks Again everyone. Jeff
