Hello,
I have problem with activation VOB2MPG program, I got error: Unable to connect to the Registration server.
Can someone fix it?
Results 1 to 14 of 14
Have you emailed the developer? http://www.svcd2dvd.com/Contact.aspx
I've always wondered why they would go to the trouble of making a license server for 12 £ product. Makes no sense, especially if it is no longer in development (is it?). If not in development, then make a server less license check version.
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
I have the same problem. This is the reported error
Server Error in '/' Application.
A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.64.86.182:25
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.64.86.182:25
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[SocketException (0x274c): A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.64.86.182:25]
System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress) +194
System.Net.ServicePoint.ConnectSocketInternal(Bool ean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) +591
[WebException: Unable to connect to the remote server]
System.Net.ServicePoint.GetConnection(PooledStream PooledStream, Object owner, Boolean async, IPAddress& address, Socket& abortSocket, Socket& abortSocket6) +6858897
System.Net.PooledStream.Activate(Object owningObject, Boolean async, GeneralAsyncDelegate asyncCallback) +315
System.Net.PooledStream.Activate(Object owningObject, GeneralAsyncDelegate asyncCallback) +24
System.Net.ConnectionPool.GetConnection(Object owningObject, GeneralAsyncDelegate asyncCallback, Int32 creationTimeout) +340
System.Net.Mail.SmtpConnection.GetConnection(Servi cePoint servicePoint) +148
System.Net.Mail.SmtpTransport.GetConnection(Servic ePoint servicePoint) +237
System.Net.Mail.SmtpClient.GetConnection() +47
System.Net.Mail.SmtpClient.Send(MailMessage message) +1630
[SmtpException: Failure sending mail.]
System.Net.Mail.SmtpClient.Send(MailMessage message) +1998
www.svcd2dvd.com.Common.Email(String To, String Cc, String From, String Subject, String EmailBody, Boolean BCC) in C:\2backup\www.svcd2dvd.com\htdocs\Common.cs:176
www.svcd2dvd.com.Users._default.SendSerial2Email(String email) in C:\2backup\www.svcd2dvd.com\htdocs\Users\default.aspx.cs:202
www.svcd2dvd.com.Users._default.btnSubmit_Click(Object sender, EventArgs e) in C:\2backup\www.svcd2dvd.com\htdocs\Users\default.aspx.cs:128
System.Web.UI.WebControls.Button.OnClick(EventArgs e) +9796242
System.Web.UI.WebControls.Button.RaisePostBackEven t(String eventArgument) +211
System.Web.UI.WebControls.Button.System.Web.UI.IPo stBackEventHandler.RaisePostBackEvent(String eventArgument) +12
System.Web.UI.Page.RaisePostBackEvent(IPostBackEve ntHandler sourceControl, String eventArgument) +15
System.Web.UI.Page.RaisePostBackEvent(NameValueCol lection postData) +35
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1696
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.8.4330.0
Why have such nonsense license checking for a 12 £ product. Makes no sense, especially if it is no longer in development (is it?). If not in development, then make a serverless license check version.
The problem is that the registration server is offline, quite possibly for good and the website does not load up either. Basically we are stuffed.
I intend to use this in future https://www.dvdvobtompg.com/ -
No chance anymore to re-register this Pro-version-software? I get this message while trying: Please wait a few seconds whilst your machine license is generated... And I wait and nothing happens
How to decrypt this MPD link and license key?
By kienkzz in forum Video Streaming DownloadingReplies: 17Last Post: 29th May 2025, 05:18 -
How can I manually let youtube to generate subtitles?
By kenny1999 in forum Newbie / General discussionsReplies: 0Last Post: 18th Sep 2021, 18:32 -
Generate word bank in Aegisub?
By Silverleaf16 in forum SubtitleReplies: 0Last Post: 17th Jul 2019, 15:02 -
Trying to generate video from SWF
By Asterra in forum Video ConversionReplies: 23Last Post: 15th Apr 2019, 04:04 -
Generate srt from video
By meetdilip in forum SubtitleReplies: 3Last Post: 7th Nov 2017, 04:59
