    Feb 2007
    I have a movie that I watch. The movie is an mp4. I get an audio sync issue where it looks like the audio is delayed. If I rewind and rewatch that part, it goes away. Fast forwarding to that spot (actually a little before) and watching, I don't see the issue. Does this sound like a symptom of:
    1) the file being damaged
    2) hard drive damage
    or no way to tell from that limited information? Since it is intermittent I lean towards a hard drive issue, but I wasn't sure if it was a damaged file if it would always occur in the same spot.
    canada
    Sounds like more of a software playing issue.
  3. Yes, file or software. Definitely not a hard drive problem. Try a different player.
    Feb 2007
    Thanks for the responses. Tried different players before posting. Unfortunately, I can't force it to happen. It just randomly occurs.
    Feb 2007
    Remux to mkv with mkvtoolnix
    Thanks for the pointer on a tool to use to fix a damaged file. I'll look at it. My main concern is to determine where the issue lies. If this is an issue with hard drive, then I need to get a new one before doing anything. But if the consensus isit's the file, then fixing the file is all I would need to do.
    Dec 2005
    Canada
    Copy the mp4 to a flash drive and play it ? That would get the HDD out of the picture.
    If it still goes oos on the flash drive, it's probably the file or the player.
