Having edited out part of a video how do I join the remaining parts together without using Transitions?
Hi Richard,
I used 'Split' either side of the unwanted clip and then deleted it. How do them join the two remaining parts together without using 'Transitions' as I want a seamless join? -
Hi Richard,
I am using Movavi for editing.
Not familiar with Movavi but can't you just drag the remainder of the clip (after the bit you deleted) back along the timeline, or does that automatically insert a transition? I'm assuming it adds a crossfade when clips are joined? Can transitions be changed from the default to a straight cut?
It doesn't automatically insert a transition. However they are linked together after I save the video.
appending video clips with sound and clips without sound
By Betelman in forum EditingReplies: 29Last Post: 8th Jun 2019, 09:53 -
Linking Multiple AVI Into One Large File
By Genius in forum EditingReplies: 6Last Post: 23rd Feb 2019, 18:40 -
Need Simple Freeware to Extract Video Clips From Various Video Formats
By grizzle in forum Newbie / General discussionsReplies: 6Last Post: 3rd Sep 2017, 05:42 -
Looking for video player that can transition between clips
By taylor85345 in forum Software PlayingReplies: 6Last Post: 29th May 2017, 10:58 -
Linking Separate Video Files Together (Movie)
By cbeigle54 in forum Newbie / General discussionsReplies: 3Last Post: 26th Mar 2017, 14:50
