I have a Windows XP machine with this board:
https://download1.gigabyte.com/Files/Manual/motherboard_manual_ga-ep45-ud3(r)_e.pdf
I want to upgrade the video card (no gaming, no video encoding) so that I can use an HDTV as a monitor. What video card do you recommend I get?
Thank you!
EDIT: The board has "1 x PCI Express x16 slot, running at x16 (The PCI Express x16 slot conforms to PCI Express 2.0 standard)"
So I guess any video card with that, and an HDMI port should work, correct?
Not so sure that any video card would work.
You might get away with the XP graphics driver but I would have thought that more recent cards would not have bespoke XP drivers.
Now that mb looks rather similar to mine which also dual boots to XP. The card I acquired in 2008/09 was an ati HD 4600 -
I can't remember what to look for beyond drivers for XP. pcpartpicker.com told me that the following video card would work:
https://www.newegg.com/evga-geforce-8400-gs-512-p3-1300-kr/p/1FT-001K-002H6Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Sorry didn't mean to imply I was looking for the latest and greatest; there's plenty or "old new stock" out there, or used might even work fine. Just looking to find something compatible with the board, windows xp, and ability to plug in an HDTV (via HDMI)
I have an XP machine using a GA-970A-D3 and a AMD HD-6570 with Catalyst version 14.4.
I believe you are correct in that any PCI Express video card with HDMI out would work, just make sure it will also pass audio or you will need a way to connect the PC sound to your TV. -
admin can delete this post; they decided to go with a computer monitor instead of a TV!
No need to delete,other people might find some of the info in here handy.
Seek advice regarding graphics card upgrade
By jgg in forum Newbie / General discussionsReplies: 53Last Post: 15th Sep 2023, 11:58 -
Video appears unclean on my Tft Monitor
By Anonymous754 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Feb 2019, 18:59 -
Terrible picture problem with new monitor and graphic card
By kodec in forum Newbie / General discussionsReplies: 11Last Post: 17th Jun 2018, 14:46 -
is it really possible to upgrade the quality of a video?
By kenny1999 in forum Newbie / General discussionsReplies: 5Last Post: 6th Sep 2017, 10:13 -
Looking to upgrade computer monitor for video editing
By vhelp in forum ComputerReplies: 22Last Post: 16th Nov 2016, 06:11
