Hello,
Recently, I have been converting old Hi-8 and DV tapes to digital so we can have them on more modern SD cards. The initial capture is an .AVI file which I then convert to MP4/H265 through VLC media player. I have set the bitrate to 5000kb/sec. It all seemed to be OK until I looked at a fast action clip (skiing) and it looks horrible with horizontal lines everywhere.
Does anyone know of a good (and free) H264/H265 encoder that will handle moving action screens?
Many thanks
"with horizontal lines everywhere." sounds like interlacing,...
also you are not looking for a different encoder (VLC like most other tools is using x265), you are looking for an easy to use gui and you probably need to read up on some video fundamentals so you know enough to be able to properly configure whatever gui you end up with. (also using a media player for video conversion instead of some gui resigned especially for that seems like a bad approach)users currently on my ignore list: deadrats, Stears555, marcorocchini -
For a relatively simple editor/converter I would try avidemux.
I would also suggest you use that program to extract a short sample of one of your conversions - use copy video/audio output - so that we can also see what is going on. Maybe, also a short sample of the original fast-action footage. -
looks like the source is interlaced and should either be encoded as interlaced or deinterlaced and encoded progressivly,...
Did you upscale this for a 4k display or simply view it full-screen.
For the former, 5000 kbps would hardly be sufficient (The DV would typically have been 25000 kbps)
Screenshots really do not tell the full story (and, yes, DV should be interlaced). You will get more assistance with the samples as requested (30 secs of fast-motion footage is sufficient) and provided here as attachments.
Looking for editing software to work with H265, mp4 and ASS subtitles
By illuvattarr in forum EditingReplies: 3Last Post: 16th Dec 2021, 11:37 -
Can't seek/fast forward MP4 file.
By Cyrax9 in forum MacReplies: 4Last Post: 24th Mar 2021, 01:53 -
h265 extremely slow seek in mp4
By Ibizanhound in forum Video ConversionReplies: 22Last Post: 5th Mar 2021, 10:52 -
Converting h265 mkv to mp4
By dror.sharon in forum Video ConversionReplies: 14Last Post: 25th Jan 2017, 03:28 -
Problem converting .m2ts to mp4 h265
By ThePi7on in forum Blu-ray RippingReplies: 14Last Post: 7th Jan 2017, 03:54
