  1. hello
    is there any command in ffmpeg i want to join 2 different .mp4 video Resolution / Video - x264 @ KBPS videos
    example
    clip 1.mp4 is x264 @ 4500 KBPS and Resolution - 1280 x 720
    and
    clip2.mp4 is Video - x264 @ 1400 KBPS and Resolution - 704 x 400
    can we still join them in 1 clip
    both clip quality should remain same but video dont go out of sync
    thanks
  2. It's possible to do that but most players will choke at the resolution change. First make a text file with a list of files to be concatenated:
    list.txt:
    file 'clip1.mp4'
    file 'clip2.mp4'
    Then run:
    ffmpeg.exe -y -safe 0 -f concat -i list.txt -c copy output.ts
    TS is safest for the output.
  3. Originally Posted by jagabo View Post
    list.txt:
    file 'clip1.mp4'
    file 'clip2.mp4'
    Then run:
    i tried file 'clip1.mp4' 720p works fine but file 'clip2.mp4' 480p video comesout bad messed up quality green lines in video unwatchable
  4. I told you so.
    Try a different player. Did you use TS or MP4? TS is safer -- more players can handle the resolution change in TS.
  5. Does it really have to be "a single file"? Usually such stuff is done using playlists, e.g. m3u...
  6. Originally Posted by emcodem View Post
    need more details
  7. Originally Posted by grabyea View Post
    need more details
    https://en.wikipedia.org/wiki/M3U
    It's just a text file. It can have as little as name two videos (if in the same folder as the videos) or full paths to the two videos (if in a different folder than the videos).
    video.m3u in same folder as the two videos:
    video1.mp4
    video2.mp4
    or
    video.m3u in a different folder:
    d:\videos\video1.mp4
    d:\videos\video2.mp4
    Then you "play" the m3u file with a media player. Pretty much all players in Windows support this. The files don't have to have the same properties. They can be different frame sizes, frame rates, codecs, containers, etc. As long as the player can play the videos it will play them all. Playback may not be seamless though.
