    Apr 2002
    Florida
    i have a rare anime video i d/l from the internet due to its raraty i want to back it up. it is in divx 5 however when loaded into TMPGenc or virtual dub it goes all currupt but the file is good the video plays in any media player but the audio wont play in anything other than the player 2.0 released by divx.com is there a way to salvage this or am i just gong to have to find a biger cd?
    thanks
    Static is in the minds and hearts of all mankind the sad part is... that we never fully comprehend the concept that is static.
    Apr 2002
    Florida
    i hate doing this but i realy need help : bump
    Mar 2002
    chicago
    thanks
    did you try to open the file in virtual dub, open the extended options(or whatever the button says) and rederive the key frames, and then do a direct stream copy, or, if you have room, full processing mode, uncompressed avi and use that?
    Apr 2002
    Florida
    when i hit play in vdub (not doing any thing special) i get green boxy courrptness. not sure if that helps you (no i havent done what you said but i didn't think it would help cause of the greenboxy ness)
