Apparently I don't have the required credentials to post a poll in the dedicated category, so I'll put this here.
Considering the staggering amount of Windows video and audio editing / converting / downloading tools which come with their own copy of ffmpeg (often making the bulk of the utility's total size), I commented about a year ago on the fact that it can add serious clutter to the system partition, and also lead to unpredictable results as the version being actually executed when typing a “ffmpeg” command without specifying the complete path is not necessarily the most recent (as I recently found out).
So how many distinct instances of ffmpeg (.exe or .dll) can you find on your system, for what total size ? How old is the oldest one ? (Last year I found 17 instances for a total size of 751,8MB. By now it's probably above 900MB. Counting the equally redundant instances of (lib)avcodec could double the total.)
At this point it would be welcome to have yet another tool to manage this mess, keeping only the most recent version (with an option to automatically update it), and replacing all others by hard links — if someone feels up to the task of writing something like this...
As far as I know Linux systems don't have that kind of issue (only one version of any given utility is installed in a specific place and any other tool relying on it calls it from that place — sorry for the Bill Gates “the thing that does the thing” kind of talk). Don't know how MacOS and other operating systems behave in that regard.
I have 8 copies of ffmpeg exe or dll. Four of those I installed and 4 came with other software. Total size < 185 MB, nothing close to the nearly 1TB of dotNet crap.
ffmpeg's APIs are not backwards compatible across major versions so you couldn't necessarily replace all instances with a single hard link though you could probably get it down to 2 or 3.
Since most people using Linux only install software from the distribution's package repositories they are unlikely to run into problems like you describe with ffmpeg. But you can certainly have more than one version of a program on Linux. -
...nothing close to the nearly 1TB of dotNet crap.
(Last year I found 17 instances for a total size of 751,8MB. By now it's probably above 900MB. Counting the equally redundant instances of (lib)avcodec could double the total.) -
1
i run Linux and am not downloading all those various packages. it's standard in the Linux community to not include other projects like that, especially if it comes builtin like ffmpeg does in desktop-intended editions of Linux. an edition of Linux for a server should not have any copies of ffmpeg by default but you usually can install one copy if you want to do background work on your server with it.
Question about Vegas - clip size / project size / system load
By P195 in forum Newbie / General discussionsReplies: 2Last Post: 20th Oct 2019, 23:17 -
ffmpeg lower the total bitrate after extract
By UnlikeME in forum Video ConversionReplies: 5Last Post: 4th Feb 2018, 04:52 -
FFMpeg reports wrong video size ?
By alexander121 in forum Video ConversionReplies: 3Last Post: 13th Oct 2017, 11:03 -
ffmpeg: how to encode @ target size and 2passes?
By marcorocchini in forum Newbie / General discussionsReplies: 26Last Post: 28th May 2017, 19:55 -
Avisynth total frames does not equal VirtualDub total frames
By EasyFeet in forum EditingReplies: 12Last Post: 14th May 2017, 01:20
