When I am trying to split this one movie, it keeps saying "PTS underfloww" and "DTS underflow", and when it's finished, the video chops up near the split point. Any idea what is going on and what all that means? Thank you.
Just read your bbmpeg log file, it tells you what the problem is. your total bitrate (video + audio) is exceeding the limit allowed in the svcd specs. Set forced mux rate to 0 (automatic) and then multiplex.
This will result in a properly multiplexed mpg but you will essentially be making an xsvcd so proper playback on standalone dvds won't be guranteed.
A buffer underflow is when the data cannot be sent to the buffer fast enough during playback, resulting in choppy playback.
BBMPEG Multiplexer Question
By Krelmaneck in forum Newbie / General discussionsReplies: 16Last Post: 22nd Apr 2011, 23:59 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
bbmpeg xp patch , page not found
By rabbit_hgc in forum EditingReplies: 8Last Post: 15th Jul 2009, 05:45 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
