I am not trying to resize the video. I want to make the editor section bigger so I can be more precise with dragging things around on the actual editor window. I can't find anything about this online because Google keeps giving me results about resizing the video, which is not what I want to do.
[Attachment 61163 - Click to enlarge]
Results 1 to 14 of 14
It may not be obvious to everyone which editor you're talking about, I can't tell.
Uhh....VSDC? the one this entire forum is for??? At least this is the only one that came up about it on Google
This section of the forum is for all editing software, not just VSDC. There are plenty of video editors out there both free and paid. I would suggest you choose one with a better GUI. Have a look at Video Editors in the Software section above.
Canon G40 - Dell XPS8700 i7 - Win 10 - 24gb RAM - GTX 1060/6GB - DaVinci Resolve Studio 17.4.6 - Blackmagic Speed Editor - 2 calibrated screens -
You seem to be under the assumption I'm new to the software - I've been using it for years and it does everything I need it to. I just want to make the view bigger so I can make precise adjustments when moving things around.
So, instead of condescending to me, answer the ACTUAL question. I don't have time or energy to waste on beating around the bush. -
Contact the authors and ask them directly:
https://www.videosoftdev.com/support/feedback -
I downloaded the free version of VSDC to look at the user interface.
For most software where the ability to magnify/reduce makes sense, the View drop-down menu on the Menu Bar, or a Settings drop-down menu, or a context menu contains settings/controls that allow magnification (Zoom In) or reduction (Zoom Out). However, VSDC only has settings to show/hide Toolbars, the Timeline, etc., in the View drop-down menu and Settings, causing more (or less) of the program window to be devoted to displaying the video and nothing remotely useful in a context menu.
My guess is that the free version of VSDC doesn't allow what you want to do. I can't say if the paid version behaves differently.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Thank you. This is the conclusion I was floating towards but I figured I must have been missing something since I don't really explore the setting much aside from searching through settings and such this morning specifically. I'm also only on the free version so who knows, maybe I'll discover something when I can eventually afford the upgrade.
I just thought of something else to try, the zoom-in and zoom-out gestures on my laptop trackpad. Surprisingly, this worked! (I first moved the cursor into the center of the video window pane. Afterward, placing both index fingers together on the trackpad and pulling them apart zoomed in. Placing both index fingers some distance apart on the trackpad and pushing them together zoomed out.)
[Edit] I tried placing the cursor in the center of the video window pane and clicking, afterward typing Cntl+ or Cntl- also worked.
[Edit 2] I hid everything that I could, other than the viewer, then did some screenshots
[Attachment 61178 - Click to enlarge]
[Attachment 61179 - Click to enlarge]Last edited by usually_quiet; 7th Oct 2021 at 11:44. Reason: In Edit 2, I cropped screenshots to screen size and re-wrote for clarity
"You seem to be under the assumption I'm new to the software - I've been using it for years and it does everything I need it to. I just want to make the view bigger so I can make precise adjustments when moving things around".
I assumed you were a new user as that is the sort of question asked by a newbie. It's surprising then that you don't know VSCD's capabilities.
I'll be even more condescending, try reading the manual.Last edited by ChapmanDolly; 7th Oct 2021 at 05:24.
The first thing I did was to skim VSDC's help/documentation/FAQs to see if there was any help with this problem there. If you managed to find a solution, good eye! I failed to find what I was looking for.
So, I resorted to a trial and error approach. The keystrokes and gestures that finally worked are standard for Windows but the focus has to be on the right object in the UI for them to work.
I am hopeful that Snöiller Fitzroy's VSDC problem is resolved but I can't say for sure since he has not returned to say anything.Last edited by usually_quiet; 7th Oct 2021 at 14:35. Reason: corrected spelling
make jpg bigger without losing quality
By David Banner in forum Newbie / General discussionsReplies: 12Last Post: 8th Feb 2021, 17:01 -
Anyone know a free windows editor trust can make many chops in one pass (wi
By Goshite in forum EditingReplies: 2Last Post: 17th Dec 2020, 15:38 -
Handbrake: Subtitles become bigger when burned in
By Hakunamatata67 in forum SubtitleReplies: 6Last Post: 22nd Nov 2020, 00:45 -
webcam with bigger field
By denno in forum Newbie / General discussionsReplies: 9Last Post: 10th Apr 2020, 08:48 -
Please make audio waveform feature to VSDC free video editor
By FreeBoomer in forum EditingReplies: 0Last Post: 6th Apr 2020, 04:39
