Hi Everyone ,
I came across a website LINK : https://www.nekomeowmeow.com/marcheep01/
it has video embed on which it overlay subtitles . I tried to inspect it's element but did not able to find any srt or vtt or xml which has substiles related to it .
Also i am able to download video and i am sure those subtitles are not hard coded .
May any one please help me regarding it ?
Closed Thread
Results 1 to 9 of 9
MediaInfo might be able to tell you what format was used.
Download and install MediaInfo.
Open the file that you downloaded with MediaInfo
Click on "View" and then "Text"
Copy the entire contents of the window.
Paste the output from MediaInfo into a reply to this thread.Ignore list: hello_hello, tried, TechLord, Snoopy329
Well, the issue here as I understand it is to retrieve the subtitles overlayed on the video when it is played from that web page, which are most likely not embedded within the video stream (which happens to be a standalone MP4 file), so MediaInfo won't be able to tell anything.
I tried to examine the page with Firefox's console, but it would freeze the browser with a sudden CPU usage spike, since my damn computer already crashed 3 times today I gave up quickly.
Thanks you @abolibibelot and @usually_quiet for quick reply .
abolibibelot is right MediaInfo won't be able to tell anything . I will post it in Video Streaming Downloading section if i can get some help from there .
Output mediainfo:
General
Complete name : C:\Users\rij\Downloads\Video\ma01.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 1 014 MiB
Duration : 1 h 6 min
Overall bit rate : 2 122 kb/s
Description : Transcoded by Arctime Pro 2.3
Writing application : Lavf58.28.101
Video
Format : AVC
Format profile : High@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : avc1
Bit rate : 1 987 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.038
Stream size : 949 MiB (94%)
Writing library : x264 core 157 r2969M d4099dd
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=24.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Constant
Bit rate : 128 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 61.3 MiB (6%)
Default : Yes
Alternate group : 1Last edited by Rij; 4th Oct 2021 at 14:30.
Private message a moderator and ask to have this thread moved to the Video Streaming Downloading sub-forum.
If your video download had EIA-608 or EIA-708 closed captions (N. American TV captioning) they would appear in the MediaInfo Report.
Here is a partial MediaInfo Report for an episode that I downloaded from a free website in mp4 format so you can see what they look like.
Text #1
Format : EIA-608
Muxing mode : SCTE 128 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Duration : 23 min 39 s
Stream size : 0.00 Byte (0%)
CaptionServiceName : CC1
Text #2
Format : EIA-708
Stream size : 0.00 Byte (0%)Ignore list: hello_hello, tried, TechLord, Snoopy329
Rij-please do not open another thread on the same subject,this thread is closed,please continue here.
https://forum.videohelp.com/threads/403335-Help-Downloaded-video-does-not-have-subtitlesI think,therefore i am a hamster.
Need Help!!! How to extract closed caption of video from google drive
By moronchy in forum SubtitleReplies: 12Last Post: 5th Feb 2022, 21:07 -
Embed Closed Captions in MP4
By video2me in forum Video ConversionReplies: 4Last Post: 11th Feb 2020, 17:55 -
Encoding Closed Caption / Subtitles Into a VHS Tape While Recording.
By dellsam34 in forum Capturing and VCRReplies: 4Last Post: 30th Dec 2019, 00:11 -
How to extract closed captions from youtube video
By pirgah in forum Video Streaming DownloadingReplies: 5Last Post: 5th Feb 2018, 06:55 -
How to Rip Closed Caption from Blu-ray / HD-DVD / CBHD Video Content?
By devilcoelhodog in forum SubtitleReplies: 1Last Post: 19th Oct 2016, 14:34
