  1. I want to download some videos of my work microsoft teams sharepoint(it's a course) and I found out it's impossible for me to download the dash(yt-dlp says "DRM protected") I tried many alternatives but nothing.
    I found out that there is a dash link, but it doesn't work with yt-dlp
    Your help it appreciated
    (I can't share the login or the links sorry, since it violate my work contrat)
    If it can't be done please suggest a work around if possible
  2. Did you try --allow-u with ytdlp?
    A suggested workaround is of course OBS studio.
  3. Thank you for the answer and yes, but I get a "DRM protected" error even with the --allow-u
    I checked the internet activity in the browser and I see a dash file and other mp4 segments, I tried with the Download helper(Firefox) and I was able to see many different mp4 segments that weren't the complete video.
  4. Originally Posted by raknitir View Post
    Maybe you need headers and cookies and stuff.
    There's no mpd/m3u8?
    Can you manually download the segments?
    Can you see an init segment?
    I'm talking about Chrome developer tools -> network tab
  5. Originally Posted by [ss]vegeta View Post
    Thank you for trying to help me. There is a mpd file, but I tried using cookies. Can you please guide me to use headers?
    What do you mean with "Can you manually download the segments?" if it's about the mp4 segments I was able to download some of them(2-3 using Download helper), but they're divided in video and audio files.
    Sorry, but I'm a newbie what is an init segment?
    It's enough you point me to a site and I'll learn what you mean by myself.
    https://medium.com/@julientregoat/working-with-octet-streams-in-javascript-d43d81ad7f47
    There is also a type octet stream that is a link to a key named Videoprotectionkey.
  6. if you don't write the link to your video here, how can you hope for help? it's not possible to list the various types for a download, each site is built differently from others. so there is no general rule for downloading videos...
  7. Originally Posted by raknitir View Post
    There is a mpd file
    Download it and post it here, let us see it.
    I don't believe your employers will care/check if you shared link or cookies (so I can login) via the private message system to me.
    I can also use VPN if you want so that it looks like I'm logging in from the same country as you xD
    Don't be scared, I don't care about anything on your account except finding a way to download the content.
  8. Originally Posted by [ss]vegeta View Post
    There is a mpd file
    Thank you but I solved by using the record method
