hi anyone know last most powerful of windows processor version required for premiere 6 please? presumably xp but not how many bits etc
I don't know the answer to your question but can tell you that I run Premiere 6.5 on Windows XP Service Pack 3, 32-bit.
Originally, it was running on an Asus P4C800-E Deluxe motherboard, 1GB Ram with an Intel Pentium 4 @ 3 GHz.
Later on, I upgraded to a Gigabyte GA-EP35-DS3L motherboard, 2GB of Ram with Intel Core 2 Quad Q8200 @ 2.33GHz. This resulted in a significant speed upgrade.
On both systems, Premiere 6.5 ran well.
creakndale -
According to this Premiere 6 was released 20 years ago in 2001:
https://adobe.fandom.com/wiki/Adobe_Premiere_6
I'm guessing XP would probably be the latest Windows you can run it on, you may be able to run it on XP64, but honestly I don't see why you would want to use a 20 year old NLE. -
Agreed _Al_. When I upgraded to a AVCHD camcorder, I had hoped to edit that High Definition footage in Premiere 6.5, however 6.5 was NOT able to do it. I downloaded the latest (at that time) trial versions of Premiere Elements, Sony Vegas Movie Studio, and one other Non-Linear editor. I was partial to Premiere since I knew version 6.5 so well but so much had changed over the years that all new versions had a steep learning curve. I ended up choosing Vegas Movie Studio and eventually upgraded to the Pro version.
I still use Premiere 6.5, with the Cinema Craft Encoder plug-in, for Standard Definition projects mainly to retain my old skills and I have a preference for how I can manipulate audio in old Premiere 6.5 from the timeline.
creakndale
No capture preview in Premiere
By Ferggue in forum Capturing and VCRReplies: 2Last Post: 22nd Sep 2021, 20:05 -
23.97 / 24 in Premiere and Co
By Dagger7 in forum Newbie / General discussionsReplies: 12Last Post: 9th Aug 2021, 13:37 -
Premiere spying on me?
By cormanaz in forum EditingReplies: 14Last Post: 3rd Mar 2019, 16:57 -
VC-1 in Adobe Premiere?
By kkiller23 in forum EditingReplies: 3Last Post: 18th Jun 2017, 20:30 -
Premiere CC - can't add transitions
By Ygramul in forum EditingReplies: 6Last Post: 12th Jan 2017, 15:31
