There has never, nor will there ever, be a pause function for video capture.
Just capture the lot and you can do loss-free editing quite easily after.
Results 31 to 37 of 37
"nor will there ever be" ..... thats a sweeping statement.... surely its not rocket science
it will probably be there in the next generation
For now I ll probly go back to my old system of playing the old videos thru
my DVD recorder.... using the pause button in there to save what I like
in aprox 2 minute video files
saving all those on a dvd
putting the dvd into my comp ... extracting the 20 or so video files using the free
handbrake software
and thats job done rw dvd s are not expensive....
though they might not be available for much longer... !
just like they stopped manufacturing video players some time ago !
all thru the 80s 90s etc I recorded bits and pieces of TV
and never re used the video tapes... thus I have a wardrobe full of
400 or so tapes to go thru and sort out the best bits.
.Last edited by silverstar2003; 4th Oct 2021 at 13:04.
The discussion has come up fairly often.
The 'difficulty' might well have to do with disk access and not corrupting the existing file at the point of resume.
I am not familiar with the device that jagabo mentions but I always thought that Hauppauge devices, and I have owned two, including the one I use right now, used WinTV for capturing. My device uses v7 there are later versions now. The capture window does have a pause button and it does zilch other than pause what you are previewing. Everything is still captured. -
Highly unlikely, with the way Microsoft nuking any capability of capturing video in every update odds are not in your favor, Beside who does DVR like this? take a glory widescreen HD digital video from a satellite receiver and butcher it down to a crappy SD analog video just to recapture it back to digital in an inferior SD quality with chopped off sides of frame to fit in 4:3 aspect ratio. I know I wouldn't.
No... my system of using the dvd recorder to record my old vid tapes and then get them
onto the computor works fine and gives good quality video files no probs
I paid £40 to get the vid2 PC SOFTWARE ... sadly no pause button but it will
give me the option of getting 600 plus tv channels into my comp and if nothing else having some audio
to listen to when on the internet....
But just thought of another option..... get my old videos playing on the showbiz software
then get up that free software..... Debut Video ..... and use that to capture the video playing in
the tv window.....
Debut video does have a pause button !!
It sure does...
And it captures a still image until you press record again. Not really what you want is it ?
Satellite tv tuner for a HTPC North America
By Muscleman in forum Newbie / General discussionsReplies: 8Last Post: 19th Feb 2020, 17:40 -
Toshiba Satellite UEFI Boot
By SIRCOOKS in forum ComputerReplies: 2Last Post: 14th Nov 2019, 09:50 -
avisynth with a programme recorded off the TV (satellite STB)
By pooksahib in forum Video ConversionReplies: 1Last Post: 29th Nov 2017, 16:31 -
DVBSub2Text and French DVB satellite TV subtitles
By naszdom in forum SubtitleReplies: 7Last Post: 24th Oct 2016, 10:19
