On another forum, I was recommended this method to upscale some of my videos. The method that I used was "Nearest Neighbor" resize where I do a "Same as Source" aspect ratio option with another resize filter with "Lanzcos3", "Compute Height from Ratio" and the "Y Value" being 100%. I had been looking other methods of upscaling my gaming videos and I am starting to think this method might be outdated and it may not be good for me in the long run. I also want to trim my videos as I do not want to make any longplays as much as I want to do individual levels. What is a better method to do this type of work? Should editors like PowerDirector? Or should I use something like FFMPEG or AVISynth? 3D images are not the same as pixel art so I want to know what should do?
Results 1 to 15 of 15
Too vague
It depends... on what your goals are, what kind of video games, what video format, what kinds of edits (just cuts or do you need more like transitions, overlays, or more fancy stuff? ) , what programs you prefer and why
Maybe start with why you are upscaling in the first place -
I wanted to upscale it to meet Youtube's standards for HD but I also wanted to keep the aspect ratio. I mostly wanted to utilize PlayStation games and upwards and I mostly use Virtualdub2 to uspcale the clips that create rom those videos.
PS1 games ?
If they are 4:3 , you don't need to do anything special such as pillarbox - YT supports them directly e.g. 960x720 is 4:3, you don't need 1280x720 pillarbox
Why don't you test it on a short sample and see if it looks ok ?
Point Resize is to preserve blocky pixel look, for things like dos games, pixel art scaling. There are dozens different types of algorithms
https://en.wikipedia.org/wiki/Pixel-art_scaling_algorithms
For the scaling it depends on your goals - what do you want it to look like ? There are "AI" / machine learning based algorithms for game upscaling too - that can completely transform the look, making them almost look like modern games - but they are generally much slower. So if "time spent" was part of your criteria you might factor that into your decision -
I will have to give a shot. The truth is I am a little afraid as I do not want to screw it up really badly but I will try my usual method a shot.
What exactly do you mean by "3D" images? Real-life images? 3D CGI images? Stereoscopic 3D images? Those might all have different resize requirements.
Scott -
I meant 3D CGI images like the ones used in video games or movies.
Some examples of non-antialiased pixel art enlarge 4x:
[Attachment 61037 - Click to enlarge]
Note that antialiased graphics will give different results. -
For the resizing size, If the source video is 4:3 just resize to 1440x1080 square pixel, YouTube will display it in perfect 4:3 ratio. I find Lanzcos3 gives better visual quality after YouTube compression is applied compared to other resizing techniques.
What look best depends on the algorithm that's used. PointResize() will look best with integer scaling of pixel art video. So a 320x240 source won't look good at 1440x1080 (4.5x scaling). Enlarging by 4x and adding borders to 1440x1080 will look better.
Not for pixel art from emulators of old video games. Lanczos looks horrible what that.Last edited by jagabo; 29th Sep 2021 at 13:07.
It depends on the "look" he is going for, the specific game, the type of sprites, type of dithering, shading model, pallette used, type of art styles
Sometimes there are mods that re-texture in-game, and there are various "AI" models to transform them
eg. Because old games used a limited color pallette, they used techniques like dithering to create "shades" of fake colors
"De-dithering" is an "in" thing for older retro games in some circles- it's using algorithms that interpolating the blocky dithering patterns and "fill" them as if it had used a pallette with more colors in the first place
original
[Attachment 61051 - Click to enlarge]
lanczos3
[Attachment 61052 - Click to enlarge]
ESRGAN PixelPerfectV4
[Attachment 61053 - Click to enlarge]
But on the other end of the spectrum is retaining the blocky pixel classic look
There are mods that go the other way - they create blocky pixellated minecraft-like look from modern games - transforming them to "retro" style -
Upscale and downscale = better quality?
By Quantumleap in forum Video ConversionReplies: 5Last Post: 4th Apr 2021, 02:16 -
What is the best way to upscale videos.
By Felow in forum Video ConversionReplies: 15Last Post: 9th Jan 2020, 16:00 -
How could you upscale SD to HD in Virtual Dub?
By nicksilverstein in forum Newbie / General discussionsReplies: 3Last Post: 24th Feb 2019, 05:19 -
How to upscale a video using waifu2x?
By claublog in forum Newbie / General discussionsReplies: 6Last Post: 26th Mar 2017, 12:16 -
Upscale 480i to 720i
By kalemvar1 in forum Video ConversionReplies: 14Last Post: 23rd Mar 2017, 20:16
