hi i need some advice,im new to all this so i will keep it short.
can any body recomend a writer for dvd & i want to put all my family videos on a disc (how)?? so if you have any spare time would you please recomend a set up for both applications from scratch
many thanks john
If all your doing is copying VHS/Hi8/etc. family videos to DVD and have no use for customized or fancy menu systems, just go with a set-top DVD recorder. I recommend the Panasonic E20 DVD-R/RAM recorder. I have had first-hand experience with it and its ease of use and image/video encoding features and quality are superb! Check it out at --Originally Posted by elon--x--
http://profeel.com/pandmre20.htm
Kusanagi -
elon--x--,
I would recommend the Pioneer A03 or A04. These writers are well known for producing highly compatable DVD recordings. Also the bundled software that comes with it is very good. (PrimoDVD and MyDVD) -
If you decide to go the PC drive route, I agree with dmonty. You can't go wrong with a Pioneer A04 DVD-R/W drive.
Kusanagi
New PC advice
By garryward in forum Video ConversionReplies: 1Last Post: 29th Nov 2010, 13:27 -
New PC advice
By neworldman in forum ComputerReplies: 14Last Post: 19th Feb 2010, 10:17 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2008, 00:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39 -
I need some advice
By CM World in forum MediaReplies: 1Last Post: 6th Aug 2007, 05:58
