I am trying to add extra audio streams to my files with both 7.1, 5.1 and 2.0 respectively (aac, ac3, eac3, truehd, dts to aac, ac3, eac3, truehd, dts). How do I go about doing this? I have tried using both tdarr and unmanic, but I don't know what I'm doing. I want take whatever audio the files come with and duplicate it/add extra audio streams with different audio codecs such as aac, ac3, eac3, truehd, dts as well different audio channels such as 7.1, 5.1 and 2.0 respectively, although I am not sure if 5.1 to 7.1 is possible or even necessary.
i just played around with Mkvtoolnix and i didn't see any option for adding extra audio streams/codecs from the original audio, same for downmixing to 5.1 and 2.0
Drag & drop the new audiostream to the upper window, then click start multiplex.
i dont have a new audio stream, the new audio streams would need to be converted from the one that the file comes with
MKVToolNix does not reencode, it only allows to mux existing streams into the MKV container. So you would have to first demux and convert the audio, with ffmpeg or eac3to, or a GUI software relying on those command line tools under-the-hood, like MeGUI, then remux with MKVToolNix (or ffmpeg). But learning how to use MeGUI is not necessarily easier than learning basic commands to run those tools directly, and if I remember correctly it doesn't allow to convert only the audio without re-compressing the video. At this point I consider MeGUI merely as a convenient way to download and update a variety of command line tools from one place.
Removing extra video stream from WMV files, in batch + delta compression
By abolibibelot in forum Video ConversionReplies: 3Last Post: 20th Sep 2021, 00:10 -
Command line to add audio to mkv files
By Nico Darko in forum Video ConversionReplies: 25Last Post: 12th Jul 2020, 21:27 -
FFMPEG: how to batch extract all audio streams into separate mono files?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 14th Aug 2019, 15:21 -
How to Add Audio to multiple files at once ?
By Tommyman in forum Newbie / General discussionsReplies: 6Last Post: 17th Mar 2017, 11:46 -
Added 1 extra Audio/Subtitle file to a DVD, VIDEO_TS = OK ,ISO=NOT
By DeusExMachinaN7 in forum Authoring (DVD)Replies: 7Last Post: 10th Oct 2016, 03:14
